isquirrel
- Dec 29, 2012
Ours which are the current stock are all black with yellow writing, the older ones have a white base with multi coloured writing on them.
These do not glow like the mesh plates, correct? Are they less hot versus some others?
Thanks.
Do search on Takatsuki Price Japan and that will give you the answer.
What is the market value of a lightly used pair of the white base 300Bs? I just bought the newest model and may sell the older ones.
What's your impression of the differences between the two? I may be interested in getting your older ones.
You should get close to 80% of the current list price of the black based 300B if you sell it yourself. Some likes the sound of the previous. Personally, I don't really hear any difference.
Good luck.
For those with the Woo WA5, would you recommend the Takatsuki 300B as your favorite choice?
If you cannot get NOS Western Electrics, then a resounding yes!
