Dunu DN-2000 will be released tomorrow and the face off competition with H300 is imminent. I'll be looking forward for the face off result.
T-PEOS H-300 - 3 Way Hybrid Impressions and Appreciation Thread
- Thread starter H20Fidelity
k186
- Nov 14, 2011
Is anyone from here picking up a pair of the DN2k for comparison?
- Feb 1, 2011
I will be at some point
I look forward to a no holds barred comparison from you
- Feb 1, 2011
I really enjoy the H-300 so far apart from the peak. Going to get a bunch of Comply tips tomorrow, see if they help at all
d marc0
- Dec 19, 2012
Comply Ts200 works best for me without drastically affecting the H300's tonality.
waynes world
- Jun 21, 2012
Did you get those vmoda bliss tips yet? Curious to know how they work with the H300's.
d marc0
- Dec 19, 2012
Yes I have them. Unfortunately the large tips are just too big for me. I ordered medium and large but V-moda only sent me the large ones. I still have to contact them about it.
djvkool
- Oct 7, 2011
Didn't work for me too, in fact the large one is too small for my canal, it's OK for a shallow fit, but any head movement will result in slipping off, or going in too deep thus losing the seal
the old school UE100/200 silicone tips works the best, and yes TS200 works nicely for me too...
xaddictionx
- Jan 18, 2013
The stock tips are really that bad? Haven't started on these phones yet but do they require burn in?
jonyoo
- Apr 5, 2013
I actually really like the stock tips. The one's that are black silicone with the green on the inside which is the largest size. I asked T-Peos for more of these and they were nice to just give em to me since they aren't sold separately and now I use them with a lot of my other earphones at home hehe. But I still do prefer foam over silicone when commuting. As for burn, maybe into your ears as it may take some time for you to get use to the treble. Took me about two weeks. When I met Mobyn, he told me he found 50 hours to be a reasonable amount of burn in time if you're using one of those audio samples specifically used for burning earphones.
gav007
- Mar 3, 2010
Well I finally received my H-300 from the trade-in event. I cannot wait until I try them this weekend. Does anyone know if the Mobyn copper and silver cable for the H-200 still fit on the H-300?
xaddictionx
- Jan 18, 2013
Nice! Will try out the different tips included as well as some other tips like Sony hybrids and Ortofon.
Probably the treble will be okay for me as I do like a bit of treble haha. I have the RE272 which is a rather bright phone too. Hope the H300 will not exceed the brightness haha.
k186
- Nov 14, 2011
They most definitely do exceed the RE272 in brightness.
