aaronjensen
- Aug 9, 2009
I have only ever heard pops if I overload my Solitaire T at high volume in passive balanced mode with my FiiO M17 (with this DAP set to DC input and Enhanced Over Ear Mode); that's when I know I'm listening far too loud. Blame the effortless scaling of the cans' addictive naturalness ha ha!
However, I have never had skipping or pops when using any audio apps, wireless or wired, to the Solitaire T.
Unless you can troubleshoot your source device (updates, delete cache, etc), perhaps consider contacting your dealer and request a swap to another pair.
Of course, please troubleshoot as much as you can first, maybe use another device to be on the safe side.
That's interesting. And somewhat concerning. Also of note is I had what appeared to be mold/mildew in my box when I opened it up. It wiped right off, but super weird. I've had it happen with both my phone and my mac book, so not sure about sources. One thing w/ the Bose was that they mainly did it when you were connected to more than one device. Do you have multipoint/multiple devices connected? I'll see if I can figure out if that's connected to my issue.
This is a mindfield; we have an overflooded market of high quality amps and DAC's everywhere.
@WDitters is 100% correct, JDS Labs are king for sonic quality, objective measurements, and exceptional value. They are not the last word in sonic quality, but objectively, what any JDS Labs Atom amp version offers is astounding. It will be more than sufficient to power the Solitaire T.
Ditto your own consideration of Hel+ or Moda 2.
Topping A50s is another powerful and affordable option too.
Or consider the recent Astell & Kern PA10, a portable amp (Class A) but no DAC.
Another recommendation is Chord Mojo 2 (single-ended, and wireless with Poly 2). This should also suffice.
If you want to use your phone as source, the FiiO BTR7 dongle is great too, with almost latest Bluetooth spec and SE + balanced outputs.
DAP's is crazy complicated to get into, but FiiO M15s is a great start imo.
There are a lot of options, so demo where you can, and consider features, benefits, lifestyle needs, and sonic quality to pair with your Solitaire T.
Hope this helps!
Thank you for the suggestions. I actually meant Chord Mojo 2, not sure why I said Moda. I've heard quite good things about the Mojo 2. I wonder how it compares to the JDS. I like the look of the Element... and that it's one box. It looks like the Atom are two separate boxes for amp/dac. I don't really have many places to demo around here, so I'll probably end up just picking something and hoping that goes well
