I know the bar is being set quite high but if it's not better than a Shang Sr & T2, I'm not sure there is a point. Or edit and place your favorite stat in place of the Shang Sr.
Summit-Fi Random Thoughts
- Thread starter Ciggavelli
Agreed 100%. I'm expecting Shang Sr resolution with CA bassI know the bar is being set quite high but if it's not better than a Shang Sr & T2, I'm not sure there is a point.
Wouldn't the Shang Sr set you back about 14k street, and the T2 16k or something? So that's a combined 30k. The Immanis + TOTL amp should come well under that, plus you can use the amp for all your other HPs except estat (or you can spend well under 15k to get the Immanis + a used good condition VM1a).I know the bar is being set quite high but if it's not better than a Shang Sr & T2, I'm not sure there is a point. Or edit and place your favorite stat in place of the Shang Sr.
dude120
- Dec 11, 2010
Assuming its tonality is good, wouldn't that make it (hypothetically) better in almost every conceivable way than the HE1?Agreed 100%. I'm expecting Shang Sr resolution with CA bass
While I understand your application of money in this equation, once you've hit MAAT, you are willing to pay for performance. If Immanis & say a 15-20k amp is better, we're still talking equivalents.Wouldn't the Shang Sr set you back about 14k street, and the T2 16k or something? So that's a combined 30k. The Immanis + TOTL amp should come well under that, plus you can use the amp for all your other HPs except estat (or you can spend well under 15k to get the Immanis + a used good condition VM1a).
ThanatosVI
You certainly have some good dealers. The X9k alone is ~7k over here, just like Immanis.was thinking about that too. but the immanis will cost more than a stax X9k + locally built megatron. waiting for Cigg to give his review on the immanis lol..
You already have a TI-1b so no need for the fancy headphone stand/Interface
number1sixerfan
+1, minus the bass expectation lol
Seriously though, I'm expecting a SGL Sr. contender resolution wise, no question. We shall see.
That’s what I’m hoping.Assuming its tonality is good, wouldn't that make it (hypothetically) better in almost every conceivable way than the HE1?
Yea so supposedly if u know where to look, the X9K is sub usd4.6k and the custom megatron is sub usd 4k. and the immanis is supposed to be usd9.5k or thereabouts?
X9k used is a sketchy purchase. Mine had driver failure, warranty is a must.
Soren is selling his 1 box MT for a bit under $6k
Dukei I think is around $7k for the 2 box with more options for customization.
Birgir is releasing a few at $6-7k
Who else is trust worthy?
What are the best bluetooth IEMs one can buy? I'm trying to get better sound outta my Vision Pro. I can't go wired, unfortunately ( )
I have the Air Pods Pro 2, but I want something even better, if it exists.
ufospls2
- Dec 9, 2014
Hifiman Svanar Wireless are good for bluetooth, but something along the lines of the iFi Go Pods is also worth considering with an even higher end IEM. There are some Chi Fi options similar to the Go Pods also.What are the best bluetooth IEMs one can buy? I'm trying to get better sound outta my Vision Pro. I can't go wired, unfortunately ( )
Thanks! I'm gonna get those Svanars. Should be an upgrade from my Air Pod Pro 2sHifiman Svanar Wireless are good for bluetooth, but something along the lines of the iFi Go Pods is also worth considering with an even higher end IEM. There are some Chi Fi options similar to the Go Pods also.
Edit: Just bought them
So when I got the Vision Pro, I also got the Airpod Max headphones. They are not bad at all. They are good for work. The bass quantity is good, but the quality isn't there. It's a bit too boomy. Still, what Apple has been able to do with these headphones without LDAC is impressive. I can't wait until Apple finally accepts LDAC as a standard. I'm an iPhone user, and don't really like Android devices. However, I'm jealous of the LDAC on Android devices. I use LDAC with my ifi go blu and it is really is good. Why Apple hasn't implemented LDAC is lost to me
- Aug 3, 2007
Are those the ones made with Fostex drivers?So when I got the Vision Pro, I also got the Airpod Max headphones. They are not bad at all. They are good for work. The bass quantity is good, but the quality isn't there. It's a bit too boomy. Still, what Apple has been able to do with these headphones without LDAC is impressive. I can't wait until Apple finally accepts LDAC as a standard. I'm an iPhone user, and don't really like Android devices. However, I'm jealous of the LDAC on Android devices. I use LDAC with my ifi go blu and it is really is good. Why Apple hasn't implemented LDAC is lost to me
I'm not sure, but maybe. They have near Fostex level quantity, but the quality is not anywhere near a th900mk2s, for example. They are good work headphones though. I'll continue to use them. For rap it works really well, but for other genres, not so much. The bass is too bloomy or booming (I can't ever remember the term, but it sounds bloated and not tight like TOTL headphones).Are those the ones made with Fostex drivers?
