Sub-bass with scene suggestions
Aug 25, 2020 at 12:14 PM Post #17 of 27
Ok, thanks! Still need any suggestions about DAC/AMP for Emu
None needed as far as I know. All Fostex variants other than t50/60rp are easily driven.
Aug 25, 2020 at 12:32 PM Post #19 of 27
Aug 25, 2020 at 12:47 PM Post #20 of 27
To answer your question (late) about the emu teak sound, gimme headroom is right, it’s closest to the fostex x00 series.
However I found the x00 bass to be a bit too much overall, whereas the emu was just right, although the bass was still strong. This really helped create a natural tone that I enjoy with modern music.
Jan 28, 2021 at 3:47 PM Post #21 of 27
Well, I just got TH-600 and I don't hear any bass, especially sub-bass. I've read a lot of reviews about them and a bit disappointed. Used them with IFI micro iDSD BL.
BGVP DMS got massive bass comparing to TH-600.
Any suggestions to further models?
Jan 28, 2021 at 4:31 PM Post #22 of 27
Give yourself some time and make sure you get a good seal on your head. If you wear glasses, try without.
Also, listen for speed and accuracy of bass and percussion. I don't have the 600s but I have models below and above and they're both great for bass quality and also for quantity I think. So I expect you will be happy after a few days of listening. The clarity of Fostex bass is amazing. I hope you will enjoy it.
Jan 29, 2021 at 3:02 AM Post #23 of 27
So are you trying to say TH-600/X00/900 are the best basshead headphones?
Jan 29, 2021 at 2:34 PM Post #24 of 27
I wouldn't go that far, but they do have strong bass while still being fairly accurate.
Jan 30, 2021 at 1:30 PM Post #25 of 27
I don't know since I'm not a basshead. But of the headphones I have heard, Fostex definitely renders percussion with the most speed and accuracy.
Feb 1, 2021 at 6:15 AM Post #27 of 27
