peranders
Member of the Trade: Sjöström Audio
- Jan 11, 2002
The size of a Jung regulator doesn't have to be too big, my JSR03 board is 57 x 37 mm and it can be made slightly more compact. So take this measures and take it times two. Heatsinks are not included but the case can be used for that.
Picture of the JSR03 regulator here.
Originally Posted by tangent It's the consequence of these two issues acting together that I'm talking about. When you replace the regulation section of a STEPS with a Jung regulator, two things happen. First, you add some more parts. These truly aren't all that much more expensive; $10 at most. But second, you have to make the board bigger, which is more expensive by itself, and it also requires a bigger, more expensive case. There's a third cost inflator, as well. I wasn't kidding when I said "five people" above. That's honestly how many people (plus or minus) have told me they were interested since I began soliciting comment in my PSU tests article. As a result, if I did make these boards, it would have to be a short run, which would probably drive up the cost to $25 per board. |
