wistily
- Jan 14, 2005
Stupid question:
In the steps building guide, there is written:
"There are two pads for AC line. The LA pad is the one to use if your fuse will be off-board, such as in the power inlet module. If you will be using the on-board fuse holder, use the LB pad instead"
However, when i look at the LA pad, i think that if you don't put any fuse on the board, the LA pad goes nowhere.
Am i wrong or what ?
