The bass hump and drop-off common to all those graphs are indicative of measurements done with leaky seal, one would do well to ignore everything around 200Hz and below when interpreting.
Stax SR-X9000
- Thread starter HBen
Blutac mod exists to work around this, stock however basically none of the more modern Stax front seal. So they will have this drop off...The bass hump and drop-off common to all those graphs are indicative of measurements done with leaky seal, one would do well to ignore everything around 200Hz and below when interpreting.
Edit: In saying that, looking at their other charts, they are getting bad seal with several other headphones that can front seal. So there's probably a bit of both here, yes the Stax will likely have some droop in sub bass, but likely nowhere near as bad as what this shows.
What's a bit questionable here is that they've come up with a Harman to B and K target...Hi dude, I just found the frequency response of the X9000 on a chinese website, also the frequency response graphs of SR-Omega and Orpheus!
https://www.woodenears.com/list?categoryUuid=eb3882ba-3d85-4e5f-8ebc-7dd270e60209
Afaik all the Harman research isn't just transposable over, nor is it possible to do a straight conversion.
So there is some salt to be taken from these.
Trance_Gott
Sure that seal is important for measurements. I had the 009s and it bass leaks vs Susvara.The bass hump and drop-off common to all those graphs are indicative of measurements done with leaky seal, one would do well to ignore everything around 200Hz and below when interpreting.
Btw the conclusion of the bass resulted from listenings by @Nomax and not measurements.
Everyone has different tastes
As already mentioned, the mids and highs of the X9000 are very good, really great, nothing disturbs them anymore
That's only two-thirds of the whole performance for me
For the one third, everyone must decide for themselves how much is sufficient for them in the low end
If someone can get used to the fact that the X9000 has less than in this third than a Utopia, you can buy this model for 7000 euros
NOMAX
PS.has the Utopia to less in this third or to much?
For my taste.,at least that's enough for me
In any case, it shouldn't be less in this area for me when I spend tens of thousands of euros
NOMAX
Blutack mod is only applicable to the SR-007A/MK2 and new lambdas that have ported ear cavities, measurements exist elsewhere that are more representative of the headphones in those graphs (minus the SR-X9000) but with proper seal. "B&K 4128" just refers to the rig they used rather than any sort of target I believe.
Subjective impressions are well and good, I only caution against drawing any sort of conclusion regarding bass from these graphs in particular.
After looking at those graphs and actually listening to them all I can say is we need more people doing these tests
Also the seal on the x9k as others have said isn’t the tightest. They rest comfortably like the susvara. The 007 has a tighter grip on my head. Anyway I’m sure all our heads are different sizes anyway.
Just to clarify Harman developed the curve on Gras rigs. They did some initial investigation into adapting it for the 4128 but found the responses differed comparatively that it would need to be redone specifically for it instead of just being converted and applied. So the fact the site offers a Harman curve overlay is telling...Blutack mod is only applicable to the SR-007A/MK2 and new lambdas that have ported ear cavities, measurements exist elsewhere that are more representative of the headphones in those graphs (minus the SR-X9000) but with proper seal. "B&K 4128" just refers to the rig they used rather than any sort of target I believe.
you just need a dac like rockna, or mojo mystiqueWhat's a bit questionable here is that they've come up with a Harman to B and K target...
or a cable like jps lite
then you will never complain lack of bass
I promise
amazing sharing! It really shows the difference between X9000 with he90 in an accurate way as x9000 is more laid back and he90 is more aggressiveHi dude, I just found the frequency response of the X9000 on a chinese website, also the frequency response graphs of SR-Omega and Orpheus!
number1sixerfan
I enjoy the CRBN, which is why I still have it. I've tested it and the x9000 and SGL Sr. extensively over the past 2 months or so. With the BHSE, Aeras and T2. It has a smidge more bass impact than the x9000, and perceived quantity of about the same. x9000 has more detailed and accurate bass. They both still have 'lighter' bass than the average planar or dynamic, just like every other stat that exists--except the 007 MK1 (and I'm sure other variations potentially).
I'm mentioning this mainly for potential buyers, as I was extremely disappointed with the CRBN's bass initially due to impressions and posts on this forum (that's absolutely not the case now after realizing why and judging it outside of these forums). The CRBN and x9000 are completely in the same realm of overall perceived level of bass imo.
If you want hard thumping bass or large perceived quantities of bass, stats just aren't the right choice imho.
orcawithabat
Yeah honestly for me my 007mk1 + a 7db boost in the sub bass and these things punch and have some of the best bass I’ve ever heard. They rumble super well and make a genre, like hiphop for example, a super enjoyable experience which no other estat or planar for that matter have matched for me (again running off a 323s)I enjoy the CRBN, which is why I still have it. I've tested it and the x9000 and SGL Sr. extensively over the past 2 months or so. With the BHSE, Aeras and T2. It has a smidge more bass impact than the x9000, and perceived quantity of about the same. x9000 has more detailed and accurate bass. They both still have 'lighter' bass than the average planar or dynamic, just like every other stat that exists--except the 007 MK1 (and I'm sure other variations potentially).
I feel stax can be bass head's cup of tea with amp like T2 ( with Mullard Tube, the bass is soul shaking), dacs like Rockna or Mojo Mystique (too tight and too much bass), and cables like JPS Lite ( too hard and too tight)I enjoy the CRBN, which is why I still have it. I've tested it and the x9000 and SGL Sr. extensively over the past 2 months or so. With the BHSE, Aeras and T2. It has a smidge more bass impact than the x9000, and perceived quantity of about the same. x9000 has more detailed and accurate bass. They both still have 'lighter' bass than the average planar or dynamic, just like every other stat that exists--except the 007 MK1 (and I'm sure other variations potentially).
I agree with Michael from Woo Audio that EQ could harm sound qualityYeah honestly for me my 007mk1 + a 7db boost in the sub bass and these things punch and have some of the best bass I’ve ever heard. They rumble super well and make a genre, like hiphop for example, a super enjoyable experience which no other estat or planar for that matter have matched for me (again running off a 323s)
paradoxper
Don't mislead @Trance_Gott.I feel stax can be bass head's cup of tea with amp like T2 ( with Mullard Tube, the bass is soul shaking), dacs like Rockna or Mojo Mystique (too tight and too much bass), and cables like JPS Lite ( too hard and too tight)
A bit too much hyperbole, the T2 doesn't transform things into bass cannons. It can help ameliorate some softness and provide adequate punch.
Total: 21 (members: 8, guests: 13)
