timb5881
- Apr 17, 2006
Just got my SR-002 setup and have tried it a little. So far so good
Glad you're enjoying them, I certainly am right now as well.![]()
Finally, got a pair to go alongside my SR-407. So far the Bose QC20i tips have helped with comfort and seal considerably. I was curious though, where did you get those hooks?I can finally connect the portable SR-001/002 to my SRM-T1 tube amplifier!A good friend built the adapter for me. It's a lot of fun to listen to the little ones. Go together incredibly well. The signature is similar to the legendary Omega in my opinion. Beautiful midrange and powerful bass. Just awesome...
Do you mean these? https://www.aliexpress.com/item/4000018001900.htmlFinally, got a pair to go alongside my SR-407. So far the Bose QC20i tips have helped with comfort and seal considerably. I was curious though, where did you get those hooks?
I've bought them - they help 003 to stay in the ear, but there is no seal yet - so no bass.you have to search for „tws k2“ Earhooks…
Hi !
For many years I listened to IEM with armature driver, but now I wanted to change something - e.g. for electrostats.
Rather portable, of course. I used shure which are very comfortable for a long time, I wanted to buy kse 1200/1500 but I did not succeed, so I am looking for staxes now, but they look not very comfortable - can you attach custom tips in them? And if so, where to order them?
Fits my ear comfortable and yes they are superior to KSE1500, I have both SR002 and KSE1500.Hi !
Are portable staxes really that uncomfortable to wear?
Original tips - Large that came in the boxYour opinion is very important to me!
Do you use standard tips or custom tips?
The SR-003 is significantly more rolled off in the treble than the KSE1500/1200, but that may not be a minus depending on your tastes.Your opinion is very important to me!
