Baten
- Sep 13, 2012
get an intona USB 2.0 isolator, it's the best. I got it used and I've never not used it since. fixes all USB problems.
i would buy these testers to check. not expensive and very useful.
That is good news , but sorry I am not very good at building PC , so I dont have much idea too. However, you now know that it is a PC problem, so may be change the PC?Bought that device today and checked all the plugs in the house - all are grounded properly.
No idea how to check if the PC that I built is grounded, but judging from what I've read online, it should be, cause the power supply has a 3 pin mains plug (should be grounded if the main plug is grounded) and it's connected to the motherboard with the original wiring.
