c0rp1
- Sep 4, 2016
Did you power it with a phone charger through the little port on the side?
I had a similar problem - buzzing coming from my motherboard's USB to my RME ADI-2 DAC. The problem was only present when I was using USB and had a video game up. Turned out it was some kind of coil whine on my video card. If I swapped to optical, it went away. If I turned off my game, it went away.
It only happened for the single-ended amp connected to my DAC, and not with the balanced amp connected to my DAC.
I ordered the ifi iDefender and it reduced this buzz substantially if I just placed it into the circuit between my motherboard and my DAC. There was still something small there, though. If I used just a standard phone charger to feed into the side of the iDefender as well, the buzz was completely gone. Based on what I've read, the iDefender uses filtering to reduce/eliminate noise on the USB power/ground lines when unpowered from the side. If you plug in an external power source to it as well, it completely shuts off the power/ground from the motherboard and only uses the power supply you're feeding to it.
You can also try taking a spare/junk USB cable and literally cutting the power lines out of it, while letting the data lines remain intact, and see if that works.
Tried powering the ifi with the port on the side via a phone charger (5V one) and the buzz is still there...
