c0rp1
- Sep 4, 2016
Hey everyone. Really hope someone would be able to help me, cause I've been trying to find a solution to my problem for almost an year now.
Basically I'm experiencing static noise when connecting my DAC to PC via USB. When I change to coaxial or optical there's no noise whatsoever.
First I was having the problem on a Modi Multibit - actually lots of people reported such issue, so I thought the problem was in the unit. Then I changed to Bifrost Multibit with GEN 5 USB and although they say that the Gen 5 USB fixes such issues, it didn't fix it for me. I bought a Wyrd to see if it will make any difference - it didn't. Bought a USB PCIe card and plugged the units there, instead of the motherboard directly - same problem.
I don't have the problem on my laptop though, so as someone suggested in a topic I opened a long time ago, I decided that it has to do with my power supply.Interesting enough though, the first DAC I had ever tried (ODAC) didn't have such issue.
Lately tested some premium dacs, such as - ADI-2 DAC, Topping D70 and a Chord Hugo 2. Both the ADI 2 and the Topping have the same issue, Hugo 2 doesn't... then I thought, what could be the difference. Well - it's the USB cables - the devices I'm having issues with are all USB-A to USB-B. Both the Hugo 2 and the ODAC don't have an USB-B input, they use Micro USB and Mini USB respectively. I tried other devices as well and that observation was correct every time.
So does anyone have any clue how I could fix this? Thanks in advance!
