Jimster480
Nope, only for 48KHz family.
It's 176.4kHz for 44.1KHz family and it is NOS at those highest source sample rates, but over all not NOS.
I'm sorry but what are you referring to?
I highly doubt it, because this DAC uses a fairly simple USB interfaceThere were rumours of a firmware update a few pages back. Does anyone have any more news? I'm wondering if it might improve compatibility with my Cayin N3 - is it Linux-based, I think it runs a custom version of HiBy - which sometimes works with the DAC3. I haven't asked Christophe about the update yet - thought I'd check in here first.
I heard back from Christophe regarding Android support. According to him a f/w update that is intended to address Linux issues is in the works, he hopes this update will help with Android as well. I would think it could help with the issues on High Sierra too. The DAC is in fact field-upgradeable which is good news but requires Windows for that. Let's hope he has enough cycles to get it done.
We established a few pages ago that the DAC3 has field-upgradeable firmware and that an update is in the works. You may have already seen this and be doubting nonetheless, in which case apologies.I highly doubt it, because this DAC uses a fairly simple USB interface
Great!!!We established a few pages ago that the DAC3 has field-upgradeable firmware and that an update is in the works. You may have already seen this and be doubting nonetheless, in which case apologies.
You need to supply 5 volts to the DAC somehow.What about data-only USB cables? Does such a thing exist? I have a couple of battery-powered DACs including this one.
I guess one could snap the power pins of a standard USB A or B plug. 1 and 4 I think.
Thanks. Yes I am using a 15v iFi Audio iPower SMPS with my DAC3. Just wondering whether there is any improvement to be gained by isolating it entirely from the USB power supply.You can also use a outboard Power supply that bypasses the Computers 5 volt power, like the USB Disrupters, etc
The cable in my experience makes more of a audible difference.
If you don't want to modify, an Sbooster Vbus2 Isolator or iFi iDefender can be used. There are data-only cables as well, I believe Curious Cables makes one (has an alt. version w/o sep. power). I am sure a lot of other diy cable makers could also make you one.What about data-only USB cables? Does such a thing exist? I have a couple of battery-powered DACs including this one.
All very helpful. iFi Defender I am familiar with and will probably try at some point. Sbooster Vbus I haven't come across but looks to be good value.If you don't want to
I am not sure about this, but seem to remember some DACs need USB-power initially to perform a 'handshake', even when they are self-powered. Easy to try out, if you snap the pins as you suggest. Might be useful for others to know, if this is the case for DAC3. Though probably the designer would know, so perhaps just ask him.
