Starting Point Systems portable NOS DAC
post-13837397
Post #301 of 470
Jimster480
Miami
Miami
Website
leaguecheats.com
So after upgrading to High Sierra the DAC doesn't work anymore. It's still being recognized, but no music coming out of it. No matter which platorm I use (Audirvana, YouTube, Apple Music). Even tried a powered USB hub but without prevail. Anybody else have this problem?
Make sure that the sample rate inside of the audio control panel hasn't been set to something that the DAC cannot understand.
post-13837414
Post #302 of 470
gvl2016
I had a similar issue on Windows with only one particular laptop but a powered hub helped. Maybe try a different USB port. Double check if somehow the DAC is being sent a format it cannot support, i.e. more than 96kHz/16 bit.
post-13837464
Post #303 of 470
Textfeud
No issue until the update. Powered hub doesn’t help. When I have the DAC selected at sound preference the OS won’t even plag Youtube vids. It just stays at the zero second mark. Same with the Apple Music. When I switch to computerspeaker no issue...
post-13837475
Post #304 of 470
gvl2016
Does the sampling frequency indicator light up on the DAC? I was thinking may be somehow new OS is sending a signal not compatible with the DAC. Is there a way to check in settings? I'm not familiar with Macs.
post-13837521
Post #305 of 470
Textfeud
I think so yes. It's on USB and everything is recognized on the Mac. Just when I press play nothing happens with every platform. So weird. Hopefully somebody else has a Mac too and can test it for me.
post-13838508
Post #307 of 470
Textfeud
No it’s just with the DAC not when playing directly through the Macbook speakers. No issues in audio/midi, everything set fins. DAC recognized. I don’t understand.
post-13838853
Post #308 of 470
Textfeud
Tried it on another Mac with High Sierra and the exact same problem occurs. The DAC is being recognized, but no matter what platform I use (iTunes, Youtube) when I have the DAC chosen it won't even play. So for instance on Youtube the video won't play. On iTunes the music won't play. I'm lost :frowning2:
post-13839193
Post #309 of 470
kvik
Norway
Norway
post-13840409
Post #310 of 470
leggoslave
I'm on High Sierra and can confirm this. DAC recognised but only computer noise is heard through USB.
I have long ago eschewed direct USB playback anyway and have been using DDCs for a few years now. Currently using a SINGxer F-1 via S/PDIF into the DAC3. There are cheaper alternatives like the Audio Breeze U8 which work just as well.
If you want to stay with direct USB I guess Christophe has to perhaps write a new driver for High Sierra. Apple's less likely to do anything about it IMO.
post-13840457
Post #311 of 470
gvl2016
Likely not a driver but a firmware update for his apparently not fully UAC1 compliant USB audio interface implementation. However it's unclear if the DACs firmware is field upgradeable.
post-13841024
Post #312 of 470
GearMe
Same here...no issues with coax. Also, it might be placebo, but I swear it sounds better than USB. :L3000:
post-13847990
Post #313 of 470
gvl2016
I heard back from Christophe regarding Android support. According to him a f/w update that is intended to address Linux issues is in the works, he hopes this update will help with Android as well. I would think it could help with the issues on High Sierra too. The DAC is in fact field-upgradeable which is good news but requires Windows for that. Let's hope he has enough cycles to get it done.
Reactions: Haden2866
post-13904754
Post #314 of 470
automojo
Wisconsin
Wisconsin
New to this site, been on Ak for years. Really enjoyed this thread.
I have tried a number of DAC's in my system, including 3 Schiit MB's, and settled on NOS, or NOS like (tubed Maverick Audio D1 Plus w/upgrades and Tesla Tube/Sparko upgrades).
Speakers in both my system are upgraded ESS AMT3's w/Great Heils, and upgraded bass drivers and crossovers. H/K amplification/preamps.
The transient response of this speaker is excellent, with sealed bass (my mods), and sealed transition/midbass driver. Low ESR crossovers my mods). The Great Heil speaks for itself in speed and accuracy. Braced and vibration treated enclosures (my mods).
I was intrigued by the DAC3, as I have been using a Project DAC Box S Fl, that except for the quad 1543T chips, and lack of USB input and batteries, is very much the same design philosophy. Built like a solid tank. It benefits from being on a hour or so before listening. I think these chips like to be warm and stabilized. The FL, and DAC 3 are deadly quiet in all modes. The Maverick D1 is pretty good too.
Surprising the Maverick sounds very close to both of these, with the Project with the most refinement. Again, they both have to be left on for at least a hour, otherwise the sound is off. I think a outboard power supply is a must. Stable voltage, and quiet.
The USB Disrupter ( clean outboard USB power supply that cuts the computers 5 volt off completely at the DAC) is a worthy investment. But I found the biggest difference on the Maverick D1, and keep it on that. As with the D1, if found the DAC benefits from a USB cable that TOTALLY isolates the signal and power wire. The Wireworld Ultraviolet does this, and makes a huge difference on the USB. It now sounds just like the optical and coax. The Wireworld Chroma does this as well, at a less expensive price, with out a silver signal wire.
I would highly recommend this to all DAC 3 owners. Its night and day. Get them on Amazon.
I do think NOS really requires the right system. I never have felt the treble lacking, of soft in any way. Just the opposite. The flow of all the frequencies is very much like how you would hear it live. The tone and flow. I would not necessarily call it analog. just natural, detailed and satisfying. Like listening to a good life performance, that's setup well.
So I have to question some saying it's not a accurate portrayal of the program material. It depends on your taste. I find super high def audio to sound totally unnatural. It's addicting at first, like Schiit MB DACS. But you find yourself listening less and less to your system. So what's the point?
To me that speaks of negatives types of distortion, that are having a huge impact on the listening experience.
At $118 plus shipping it's a real bargain IMHO. The FL runs you $299. The Maverick D1, slightly more with upgrades (it's also more of a preamp).
I think specs are a starting point. With NOS the real distortion takes place out of the audio band, not in the 20-20 range.
I also agree with the poster on having a quiet system, and power lines. It can make a big difference it what your hearing.
Again, I can't stress enough the isolated power wire in the USB cable.
I never thought it would make such a huge difference. More then any interconnect swap I have made over the years.
As well as letting the 1543T chip warm up, and stabilize before you listen to it. It sounds much different cold.
http://box-designs.com/inhalt/en/reviews/PJ-BD-DACBoxSFL-Review-Stereo-1214-EN.pdf
http://box-designs.com/main.php?prod=dacboxsfl
post-13905081
Post #315 of 470
starence
United States
United States
I just received my DAC 3 a couple days ago, and I'm really enjoying it. At first I tried it with an Eitr, but it seems to sound better with USB straight from my desktop. With shipping, I paid a little under $140 for the DAC 3, and for the price it's outstanding. I'm not sure yet if I prefer it to the Mimby, but it's in the same league. The only issue I have with the DAC 3 is the elevated bass, it can be a bit much with some music.
