axtran
- Mar 19, 2009
I was having some issues running mine on macOS after a recent patch, but I think it's since then been fixed by Apple.
I will only add to all that wise observations that in my experience that the dac2 benefit effectively of all measure taken upward to him (power supply,stones,isolation against vibrations,treatment of the electrical grid etc), and there is no more flaws after that if it is rightly implemented that I could detect,in particular his infamous so-called lack of high frequencies...Also burn-in is effective with it like said....
Richard - you should really put together a blog or website with pictures and instructions of how you implement your RFI busting solutions using stones etc - that would be very useful and very 'visually' appealing (thinking of those multi-coloured stones).
Well, good luck on your multibit adventure whatever you decide. Let us know how you get on.Thank you all for the replies...I feel that this DAC would compliment my sometimes-too-bright modded Fostex T50RP Mk3 headphones. I am still contrasting the Dac3 and the Teradak. I am NOT afraid of THD being a little higher than most would consider normal these days...I like vintage gear. And I am of the opinion that a natural harmonic profile is more important than absolute distortion quantity. I am a little concerned that the output voltage is lower than standard 2.1V. I have really enjoyed reading these accounts of the R2R sound.
I also wish the French DAC would just go with a Tenor USB chip or the like. Dated yes, but sounds good and no issues with connectivity.
