Gadget67
- May 28, 2012
I have a Phonitor 2. Here is a quote from the manual:I think you have to use one of the jumper setting I think it’s 4 to use the cross feed. Not sure.
“Phonitor Matrix activation for the XLR outputs
With DIP switch 5 the Phonitor Matrix can be activated for the XLR outputs on the rear. This is useful if you want to connect a balanced headphone to the XLR outputs.
DIP switch 5: ON = The Phonitor Matrix is activated for the XLR outputs.”
there are only two DIP switches on the XE. Neither relates to the XLR out on the rear of the unit:
DIP switches
With the DIP switches (21) on the bottom of the unit the following settings can be chosen:
Level increase of the headphone output
By using the DIP switch 1 you can increase the level of the headphone outputs to better feed power-hungry headphones.
DIP switch 1: ON = The headphone output is boosted to +22 dB.
RCA input sensitivity
With DIP switch 2 you can change the sensitivity of RCA input.
DIP switch 2: ON = The analog RCA input sensitivity is changed from -10dBV (HiFi level) to 0dBu (Studio level).”
