for spinfit I like cp100z more because of it's more shorter nozzle than cp100
SpinFit Eartips Thread - The cheapest audio upgrade
- Thread starter SpringBiscuit
Choubdia
- Sep 19, 2016
Me toofor spinfit I like cp100z more because of it's more shorter nozzle than cp100
darkarn
- Mar 16, 2012
I am using CP500 (M) now and am testing CP800 (on a different pair of IEMs, or rather, earplugs). I noticed that all sizes of the CP800 have this "suction/vacuum" effect when removing the IEM from my ears. At larger sizes, this will be more noticeable. This did not occur with the CP500 at any sizes.
Is this normal and safe for long term usage?
Noor Al-Tamimi
- Mar 22, 2017
These actually look great and I'm a little curious about them.
I've demo'd the Comply ear tips which can be nice for the bass boost but these days I'm not a huge fan of how much they tone down the treble especially on Sennheiser earphones.
I get the feeling that on say the IE800 and IE800S stock ear tips are probably the best fit tone wise over anything aftermarket such as these. Would I be right in assuming that?
Krassi
I got me some cp500 L for my tri i3 .. and i am really sad that i wasted money for this ;(...
they dondt fit and the iem is falling out of my ears with zero force holding them... for a fat earpotatoe those are not usable
Yes, it's normal, and it's not just the CP800. Just go slow when removing the IEM.
Jazz Format
Try to soak your cp500 in alcoholI got me some cp500 L for my tri i3 .. and i am really sad that i wasted money for this ;(...
darkarn
- Mar 16, 2012
Problem is, I can still feel that even when removing the IEM slowly. Conversely, CP500 and Complys do not give me this problem
Jazz Format
Does it sounds muffled?Problem is, I can still feel that even when removing the IEM slowly. Conversely, CP500 and Complys do not give me this problem
darkarn
- Mar 16, 2012
The CP800 is not with me right now (it was a demo unit from a shop) but I can recall it sounding clear
If anything, I am more worried about the suction effect harming my ear drums; I think I saw someone mentioning this in HF but I forgot the exact term for it
aldinho878
- Sep 23, 2015
Ha anyone tried the 2nd gen of these and compared to the 1st gen? Are they truly softer?
Edit: To clarify, I am talking about the 2nd gen of the single flange. Not the double flange
Zelda
- Jul 12, 2012
I have the new CP100. Yes, they are softer, specifically at the upper part. easier to get a seal with some IEMs
ryanjsoo
Reviewer for The Headphone List
ryanjsoo's Reviews
2nd what Zelda said above - Actually, I just wrote a review on them here. In summary, the new CP100 tips are softer and gripper so they're a bit more stable in the ear. The shape has also been slightly elongated for a deeper and easier fit. On close inspection, they have an E-pro-style horn on the outlet of the articulating elbow which provides less high-frequency attenuation than the originals for a more balanced and open sound. I personally have found them more transparent sounding than the originals with my IEM collection. Eye candy below:
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
Just wish they did multipacks again. Quite expensive in the uk for a pair at £14.00! Get a medium and large and you are talking £30.00 which is only £5 less than a set of impressions!
