Za Warudo
- Oct 28, 2013
I found the COP pads to work much better than the HM5 pads, which don't fit well and sucks out the bass. The stock pads still sound the best, if only they had more depth.
Calling all headphone owners, including those owning the HP100 and HP150! Want a free printed measurement of your headphones and want to help Innerfidelity get vintage, unobtainium and underrated headphones measured for the masses? Package and ship them to Tyll! Details at the link below:
http://www.innerfidelity.com/content/new-push-headphone-measurements
+1
I am sending my HP100 in for measurement (already heard back from Tyll, it should be going out tomorrow!) and this is the PERFECT opportunity to find out for sure if there's any difference between the HP100 and HP150. Hopefully someone can volunteer a set of HP150 for science!
(And remember, Tyll is paying shipping both ways so the only cost to us is not having our headphones for a bit.)
Awesome! It'll be awesome to see how they measure. I wonder how the actual measurements compare to the ones on the box.
I'm hoping he likes them and decides to do a full review. These guys are so underrated...
The left driver of my HP100 stopped working all of a sudden yesterday. Does anybody have any idea about what can be done here?
I would say 99% of the time the issue when one channel of a headphone system stops outputting audio it is because of the cable. Usually an internal short-out develops inside the wires due to the likes of excess bending or stretching of the wires. Try swapping the cable for another one. You may also try contacting SoundMagic to ask if they would send you a replacement, or contact a company that makes & sells headphone cables (there are tons of these companies on the Head-Fi forums).
Or this could also be that one of the ends of your cable is simply loose, so disconnect / reconnect both sides and try again.
i have 2 cables (the original 1 , that was sitting in the drawer most of the time, and another 1 that i bought from ebay which i used for months). i tried both of them with 3 different sources (laptop , cellphone , Modi +amp) ; got the same results, which led me to believe its the driver .. i've already sent soundmagic an email, but from previous experience, they don't have the best CS out there, so i asked here hoping for faster replies... thanks for the reply though
