dvw
- Mar 29, 2002
Ethernet is also my day job and I also worked on the standard. What is minimum distance you are talking about? The limitation of distance is actually have to do with collision domain. It is very different than reflection and jitter. There is also a jitter specification on Ethernet. In the jitter budget of the component design; jitter in cable is insignificant.
There are cases where you need a minimum cable length. This have to do with the pre-emphasis of the transmitter. This is usually in digital telephony or high speed backplane application.
I think I have gone too technical. Please PM me regarding the subject.
Originally Posted by linuxworks /img/forum/go_quote.gif ah, I just thought of another bit of possibly relevant data. my day job is computer networking. I first learned on 'thickwire' (as DEC used to call it) which is 10base5 ethernet. 10meg bits/sec with a real (!) collision domain. because of the idea of collisions on an ethernet and the fact that there are min cable lengths in the spec, perhaps -that- is another reason why I do believe there could be something to the 'too short' theory. if you think of a reflection as similar to another ethernet station randomly starting to transmit, the collsion causes a data error. fortunately, in ethernet they both detect this (and there was a JAM signal to extend it, too) and they both back off a random (diff) time and one gets to 'win' - in realtime spdif you have no such luxuries is there any tests (anyone know?) that show when a transmitter sent data, that a receiver mistook the bit? surely those that say 'cables matter' would have demonstrated this with some kind of test config and even error injectors? anyway, in the old 'hub' based ethernet days, collisions did happen and having too short a cable -was- a violation of the spec. too short from end station to repeater hub and too short from hub to hub or hub to bridge and so on. spdif and ethernet share a lot of similar concepts, if you look at it. datacomm is datacomm, at the phy level, for quite a lot of schools |
