zoiberg
- Mar 2, 2009
Its easy to see why people get confused
Originally Posted by haloxt /img/forum/go_quote.gif Because of all your silly long vs short debate I tried to put my h120 optical out directly into my dac by using a cannibalized plug to mate them together but I cut the plug too short to reach into the dac. But I still bet you're both wrong, no cable is best! |
Originally Posted by jkeny /img/forum/go_quote.gif At the risk of boring everybody, I want to post my findings, somewhat as a nod to Dan Lavry: - short cables below a certain length work if the cable is of a length such that the reflections don't return to the receiver at or during the time of the decision point... |
Originally Posted by Dan Lavry /img/forum/go_quote.gif In fact, with a longer cable, you are making the reflection round trips longer, so they will take longer to die out. |
Originally Posted by b0dhi /img/forum/go_quote.gif The question seems to be: - is it more effective to use short cable lengths and attempt to minimise the reflections before the point of detection at the receiver, or use long cable lengths and attempt to delay the reflections until after the receiver has detected the signal transition, while hoping that the trailing reflections have died down before the next signal cycle. |
Originally Posted by jkeny /img/forum/go_quote.gif This is one area where I believe Mr. Lavry is wrong - reflections are caused by impedance mismatches usually at both ends of the cable (where transmitter & receiver reside) so BOTH short & long cables will have reflections (it has nothing to do with length). That is the definition you will find everywhere! So that quote is totally misleading. The reflections will die out based on the exact same number of round journeys they make up & down the cable so after 5 round trips (let's say) the reflections will have died out on both long & short cables. Whether those reflections affect the decision window at the receiver is dependent on whether they arrive there during the decision window. So bodhi there aren't two different ways to do this - very high quality cables with well controlled impedances would have a reflection coefficient of -40db meaning only 1% of the signal is reflected at each cable end. So for a round trip the reflection would be 0.01% of the signal when it arrived at the receiver, the first time. The next time it would be 0.0001%. How many round trips before this level is insignificant? Perhaps Mr Lavry can tell us? This would apply to any cable long or short - completely irrespective of the length!! Most of our cables aren't this good or the impedances inside the equipment that well controlled (crappy ones 10% to 40% reflection of signal) so the approach that is available to end-users is to try to avoid the reflection clashing with the decision window by using short or long cables (of a specific calculated length or lengths) as I tried to say above! How many round trips for this worst case 40% reflection coefficient cable before it's reflection level becomes insignificant? |
Originally Posted by Dan Lavry /img/forum/go_quote.gif You really should stop typing so much nonsense. This is pretty extreme! Making up B.S. as you go along is not ok! Dan Lavry |
Originally Posted by Dan Lavry /img/forum/go_quote.gif You get around 177nsec between transitions of an SPDIF signal. The reflections (if there) go back and forth until they die out. If the cable is longer, it takes more time for the reflections to dies out, and a new transition shows up while the reflections are still active, and that will cause problems. The new transition is "riding" on reflections for previous transitions. If you want to have the reflections die sooner, with a shorter cable, the travel back and forth is faster. Given that each time the reflection gets to the cable ends it becomes smaller, with a shorter cable the decay happens faster. |
You too did not get the other point - if the cable is much shrter then the signal rise time, the reflection issue is not even there, because when the cble is real short, the signal gets there as it rises. That is why you do not terminate lines where the rise time is much slower then the delay. Examples: analog audio signals, DC, supply lines and much more. |
