plonter
- Oct 18, 2008
Hi all, just want to raise this question...I don't want to make it an argument or something,just interested to know how many of you tried different digital cables in their setups and noticed a difference in sound(for better or worse).
I just bought a new optical cable for my rig (dyton) to replace my monster coax cable i have been used so far. both cables sound good, no complain.
the reason i wanted to replace my monster cable is because in my ultra micro dac i have a small mini connection for the coaxial input(like headphones 3.5 plug connection) so i had to use an adaptor. although some people told me that the adapter shouldn't be an issue...i prefered to go for sure and still replace it with optical cable.(the ultra micro dac have a standart toslink input connection and for that i don't need an adapter!)
the new dayton optical is also shorter than the monster coax (1.5 ft. vs 4 ft.)
I am not sure,but i think that there are very minor sound differnces between the two....like in the dyton for example i noticed some echo in the sound,which i find more enjoyable and also the bass is tiny bit tighter and controlled, and the treble is more extended and smooth. i really like that sound better.
am i illusioning myself? is it psycological or maybe there are sound differences between digital cables? and if you can,please explain to me what causes/creates this sound differences. what differ the cables from each other and how does it effects the sound?
thanks!
thanks!
