About "Z1R does have some peaks in the treble frequencies which some may perceive as bright and even take offense to" - this is no longer true with the latest revisions of these headphones. None of my recently purchased ones. Someone recently confirmed it too. Apparently Sony has made some changes in tuning.
I just compared one of the very first ever made Z1R (demo unit in a store, serial number 37) with the one I own (build a year ago) and they sound absolutely identical.
So not sure if Sony ever changed the Tuning or if the reviewers who tell about the treble peaks were just telling what they've seen in the fr graph.
Maybe it's because people listen at better recorded higher quality music now .
Interesting. I listened to an old unit at a local dealer (I don't remember the number, but it was several years old) and there were high frequency peaks on some tracks. Mainly for this reason I held off buying for two years. Anyway I can't hear it on my Z1R. Maybe it also depends on the gear. Or the individual copies are different from each other?
I use an RME ADI-2 dac and even the HD800S seem to have well controlled treble. Nothing irritates me.
Or maybe my hearing becomes less sensitive with age...
No comparison as the Final would be more similar to the stock cable which is also SPC.
The Z1R shines with either an OCC Copper or OCC Silver cable over any SPC, other plated or alloy cables.
I went from the stock balanced to the AXIOS Cu (Copper) balanced and now Prion4 (OCC Silver) balanced. Going from the AXIOS Cu to the Prion4 was a huge jump in sound. Deeper bass, wider soundstage and smooth clean details across the whole
frequency range.
There's usually unit variation but it shouldn't be that overwhelming
I still don't have the perfect cable the gucraftsman is much less microphonic than others but still not as good as stock. however it's much more usable due to the lack of memory wire
The stock cable does not have significant microphonics. It is the quietest of all the cables I have for the MDR. However it tends to coil on itself and so is not idea for mobile use. The alternative cables do not coil but are microphonic.
But I don't agree. It's doesn't coil on itself more than most other cables or maybe mine is just used a lot! Picture below is stock 4.4 and Forza Audioworks Noir HPC MK2. Both great cables but Sonys better for portable use.
