leo253
Wow, pretty crazy. Saw a thread on reddit about how these were on clearance at Target for $105. Probably a pricing error, but crazy that some people got it at that price.
Does anyone know how much water these can take? I usually try to never expose any electronics to water, but what about a light drizzle outside, or say, water that splashes up from doing the dishes?
A bit misleading. Try new v4.1.1 firmware the ±2-4dB bass boost that cause bloomy bass are now at reduced rate to almost flat response so the XM3 bass are now much clearer and more articulate. Also with reduced bass, XM3 mid and treble are more clean, clearer and livelier.But sound is bassy in a slightly irritating way.
To me ANC was the reason to buy the XM3s. It is brilliant and almost addictive. The sound signature is very good for me, but you can modify it with the software. Works very fine, your settings are saved in the XM3s. And they are very comfy, although tend to warm your ears. I previously had the wired P7. Heavier and less comfy but I loved them. Have heard that the wireless P7 should be even better? Nevertheless, they are probably better sounding than the XM3 without ANC turned on. But you should try to compare with your own ears......Hi folks,
Have read so much about these cans but have not found so much info about a direct comparison between this model and the bowers & wilkins p7 wireless (that I already own).
I'm very curious about that because, despiste I love my headphones they are far from being perfect in terms of comfort for my liking.
I have tried many bluetooth models, including the sony XM2 model (liked so much its comfort but they had so much worse sound signature comparing with p7) and also the PX (preferred the P7 model over this one due to comfort).
So, in your opinion you would change my p7 wireless for this sony model? If the answer is yes, why?
Please take into account that for me ANC is not a must and probably won't use it.
Thanks in advance!!
A bit misleading. Try new v4.1.1 firmware the ±2-4dB bass boost that cause bloomy bass are now at reduced rate to almost flat response so the XM3 bass are now much clearer and more articulate. Also with reduced bass, XM3 mid and treble are more clean, clearer and livelier..
Hi folks,
Thanks in advance!!
