Sony WF-1000XM5
Mar 14, 2024 at 6:59 PM Post #1,006 of 1,029
Any news on the WF-1000XM5's getting Auracast support?
Mar 26, 2024 at 5:08 PM Post #1,007 of 1,029
Hi,
bought WF-1000XM5 today in order to replace Senn MTW3 because I would like more livelier sound, but no matter how I tune WF-1000XM5 sound in their app, they sound pretty edgy to me. Is there some chance that they would after some hours start to sound more relaxed?
Thanks
Mar 26, 2024 at 5:19 PM Post #1,008 of 1,029
Hi,
Thanks
Try this EQ, that someone mentioned about one page ago:
Mar 27, 2024 at 2:51 PM Post #1,010 of 1,029
Thank you, but unfortunatelly did not help. Guitars are stil way sharp and with pronounced edge.
Have you tried different tips? Comply foams do sound different and are good for optimal ANC (prefer those for the Sony stock)
Mar 27, 2024 at 10:06 PM Post #1,013 of 1,029
Mar 27, 2024 at 11:53 PM Post #1,014 of 1,029
Thanks TooFrank. Further listening shows me that I don’t like so tight and brittle character they have. I prefer more layered and relaxed, but yet dynamic presentation. I tried silicone tips, but cannot remember who made them and that edge is still there.
I just bought a pair to replace a pair of XM4s. Try taking the bands above 400 hz down 2 ticks, if that’s not enough take the middle two bands down another tick or two. Get it close and then give your ears a week to adjust.
Good luck, hope they grow on you like they did on me…
Mar 28, 2024 at 4:06 AM Post #1,016 of 1,029
Thanks. Tried that with EQ, but no luck. It is their core sound. Everything sounds forced, edgy and way too tight… and I like tight and grippy sound, but this is way too much.
Do they mellow out a bit after some hours?
Sounds to me like you might like the XM4 more than the XM5
Mar 28, 2024 at 5:17 AM Post #1,018 of 1,029
I don't think it will change, if it's not a equalization issue. Try at least the custom eq with the wizard.
Anyway never heard the Tw3/4, but I know quite well the typical sennh sound...quite slow, relaxed, not punchy, mellow. XM5 will never sound like that
Mar 28, 2024 at 12:18 PM Post #1,020 of 1,029
In my case yes. It started getting better at 40 hrs and improved more from there. However they never sounded edgy to me, tight yes.
