joshnor713
Pic?I liked Symbio tips, but got very uncomfortable after a couple hours, which is why I mated them with the Spiral dots
Same here. Symbio (and even Sedna) are too hard for longer sessions. SD (not ++) are easily the most comfortable, followed by Acoustune AET 07. Then again I don't like a deep fit as it's too uncomfortable for me and I'd rather compromise with less isolation.I liked Symbio tips, but got very uncomfortable after a couple hours, which is why I mated them with the Spiral dots
That's definitely not how they should fit! See pic below for how they fit for me: completely flush against my ear with just a gentle push inward, and the tips (Spiral Dot medium small size) don't sit too deep either, just past the opening to my ear canal and very comfortable. I can hardly feel them after a while. You shouldn't be able to get anything between the earpiece and your ear. Either the tips you're using are too big, or too long (deep). I can shake my head vigorously and they don't move around at all.I feel like these sound very different depending on how you wear them in the ear. I mean OBVIOUSLY they do, but they're overly sensitive to fit in my experience.
I used to really try to get them to fit deep in my ears (because I like that fit and it usually feels more secure) by sort of pressing them into the ear by pushing down/in on where the little gold/rose gold or bronze-colored detail is and they get a way better seal but I think they sound worse that way.
Also, how do they fit in your ears. not comfortwise but like... physically? I feel like my ears are weird, but I would expect them to be somewhat resting completely straight against the concha, but for me the top part of the earbuds jut out quite a bit which leaves a bit of a space behind the earbud, enough to get a finger in between my ear and the earbud.
I don't think i've seen it sit like that in other peoples ears when i've seen images but i'm not sure.
On a separate note, I have way too many grey hairs now!
WARNING: fuzzy ear shot below, not for sensitive viewers.This is how they fit me right now if I want a good seal. I don’t think I wear tips that are too large, on the contrary I feel like they might be too short, which is why I need to push them down and in and make them fit like this.
I can get them to ALMOST sit flush with my ears if I just pull them out a bit from my ear canals, and I can tell that you’ve rotated the earbuds more so that the bronze accent (is it the mic?) is aimed down a bit more than mine are. But if I wear them like that, I don’t get a seal at all and lose all noise isolation both passive and active.
This is wearing the Large stock WF-1000XM3 stock tips btw.
(Sorry about my fuzzy ugly ears btw)
Yes mine sits flush like that as well using SpiralDot++, SpinFit or FinalE tipsWARNING: fuzzy ear shot below, not for sensitive viewers.
Ok so I've tried taking a shot from a similar angle so you can see what I mean by the IEMs sitting flush (apologies for the focus, hard to shoot accurate selfies of the ear). Give a few different tips a try maybe? I find silicone works much better than foam for me, and Spiral Dots are particularly comfortable (pillowy soft) and quite shallow. Good luck experimenting!
This video is much more interesting than those saying "Wow, what a base! Listen to Jay-Z. These are my new n°1" or "These earphones deliver deep base and crystal clear treble".
