natalieann
- Jul 23, 2015
I have tried both these and the Beoplay E8 and I prefer the Beoplay much more in terms of comfort, and sound quality
Aw damn it! I only plan to use these to work out so I may keep it if there's a drop in price for Black Friday. I'm a sad panda though. Thanks for testing and reporting back here. Very much appreciated. One more thing. How often do you experience drops? Say for instance you were walking outside for half an hour.Outside again today and tried secure connection and have the same problem..Guess they go back.
Thanks so much for putting in the work to report everything you've found. Much appreciated. Looks like the tech isn't quite there yet. Unfortunate because apple seems to have nailed it. Perhaps they have a patent on some sort of superior tech. Either way, I think I'm going to return mine and wait for WF 1000xmark2 or whatever it will be called.this is one article that talks about the problems that the bragi dash had, I had them and they were terrible even after update. don't these problems sound very familiar?
https://www.theverge.com/circuitbreaker/2016/12/4/13822944/bragi-dash-software-update-review-how-to
If I stayed in the same place they cut out every now and then but when I walked around the right side was cutting out so much I couldn' take it anymore..Heading back to best buy now..Aw damn it! I only plan to use these to work out so I may keep it if there's a drop in price for Black Friday. I'm a sad panda though. Thanks for testing and reporting back here. Very much appreciated. One more thing. How often do you experience drops? Say for instance you were walking outside for half an hour.
This sounds absolutely intolerable. Mine goes back as well. Thanks again.If I stayed in the same place they cut out every now and then but when I walked around the right side was cutting out so much I couldn' take it anymore..Heading back to best buy now..
I returned two pairs and I use iOS. Lots of cut-outs.I may be wrong but going through this thread there appears to be some anecdotal evidence that the people who are experiencing the most problems are using android handsets. I'm using iOS and, as I've said, any cutouts I've had have been normal for the place I'm in, or otherwise explainable.
I use mine almost daily for about a month now and have not faced any disconnects whatsoever. There are some instances where the right side cuts off but the sound comes back after a half second or so, and the instances are far and few. I’m using them with an iPhone 7 for what it’s worth, my Pixel 2XL should reach me late next week, will see if there is any disconnects after I switch to a Android.
