spdtdl
Formerly known as Free1066
- Dec 24, 2015
What are you all preferring?
Hybrid silicone or Triple comfort?
Dammit! After a week of flawless performance and connectivity in daily use around the house and out in the park, the earphones have started showing the dreaded right-earpiece drop-out problem. This happens irregularly but frequently, several times a minute, and makes music listening impossible and is too distracting even for talk-show listening.
I've tried all the suggested fixes, including selecting connection quality over sound quality and a factory reset, but the problem persists. Weird and disappointing - I was really enjoying them.
I've contacted Sony for repair or replacement under warranty.
I don't think that's the case with the WF-1000X. I tried walking away from my phone with only the right ear plugged in, the left plug remaining with the phone, and the connection was just as good/bad as before. I'll have to try what happens if the left plug is far away from the phone (but still within range), and the right one is nearby.According to Apple, current BT IEMs that are not wired together pose a major challenge with latency. This is because BT is only wirelessly connected to one ear piece. After that, the connected earpiece has to wirelessly relay the other channel to the other earpiece. In order for right and left channels to stay in sync, there is some buffering required. This was the main reason why Apple created their our wireless technology that enables both ear pieces to simultaneously connect wirelessly to the source for low latency performance. The other reason was probably due to Apple not wanting to pay the Apt-X licenses.
Left earphone is the master earphone, right the slave. Only left earphone is communicating with the phone, right earphone is only getting whatever is being fed by the left earphone, it is useless without the left earphone. Try docking the left earphone, the right earphone instantly stop playing music. However, I believe the BeoPlay E8 is also using a similar system according to their E8 product specifications(right master, left slave though), so it is curious why they apparently are able to play videos on YouTube without any audio lag.I don't think that's the case with the WF-1000X. I tried walking away from my phone with only the right ear plugged in, the left plug remaining with the phone, and the connection was just as good/bad as before. I'll have to try what happens if the left plug is far away from the phone (but still within range), and the right one is nearby.
I believe what happens is that the earphones create two BT connections to the phone, but the left signal has priority. Can anyone confirm or deny this?
Hissing sounds should only appear when noise cancelling or ambient sound is on. It's the microphone picking up noise, and playing them back inverted or not.
I can use AAC on my LG V20.
Well, they literally state this on on their product specification: "Earbuds: Right (Master) 7g, Left (Slave) 6g". Maybe they have a better implementation or better codex support, who knows. Anyway, good to know there is no audio lag on the E8, waiting for them to be available in my area so that I can try them.As I understand it the E8 uses a different technology to communicate between the 2 units and I can confirm that I don’t experience any lag from Netflix, Youtube, iTunes movies or a couple of classical music video streaming services
My bad, I thought you saying both of the E8 earphones can connect wirelessly to the source simultaneously like Apple's implementation instead of "master-slave" like most other true wireless earbuds.The E8 uses NFMI technology for the link between the 2 units so it is strange that I get drop outs and that these can be gotten rid of by deleting the Bluetooth pairing on my iPhone and then pairing again. It then works without drop outs for a few days and I then have to repeat this procedure
https://en.m.wikipedia.org/wiki/Near-field_magnetic_induction_communication
Once the left earphone is disconnected from the phone, the phone will stop playing. That's true. But if it were near field communication or something like that, how could the right side have a signal from maybe 10 meters distance? The behavior, the kind of drop offs is exactly the same with my phone at my desk, and me going to the bathroom at work with both earpieces vs leaving phone and the left earpiece at the desk and only going with the right one. It even drops the right channel in roughly the same place with or without the left channel next to it.Left earphone is the master earphone, right the slave. Only left earphone is communicating with the phone, right earphone is only getting whatever is being fed by the left earphone, it is useless without the left earphone. Try docking the left earphone, the right earphone instantly stop playing music. However, I believe the BeoPlay E8 is also using a similar system according to their E8 product specifications(right master, left slave though), so it is curious why they apparently are able to play videos on YouTube without any audio lag.
I didn't say anything about it being near field communication or anything like that, in fact Sony didn't mention what technology it is using, but it is a fact that the right earphone is the slave and it is only communicating with the left earphone not the source; you cannot use the right earphone without the left earphone being powered on and near the source. The behaviour is the same in your case because in both cases the distance they are getting the signal is the same(left earphone from phone at desk, right earphone from left earphone beside the phone at desk), try placing the left earphone further away from the desk(without moving the phone) then walk to the bathroom and see if the signal degrades sooner. Or better yet, leave your left earphone at your desk and bring both your phone and your right earphone to the bathroom and see if the right earphone is still playing smoothly. Anyway, as per trustedreview:Once the left earphone is disconnected from the phone, the phone will stop playing. That's true. But if it were near field communication or something like that, how could the right side have a signal from maybe 10 meters distance? The behavior, the kind of drop offs is exactly the same with my phone at my desk, and me going to the bathroom at work with both earpieces vs leaving phone and the left earpiece at the desk and only going with the right one. It even drops the right channel in roughly the same place with or without the left channel next to it.
I've tried the app... and it's meh. It can show me that the volume isn't at max, but I can't adjust it. Why? I need to use the Music Center app for that. Also, the EQ is a set of presets only, with visual (sort of) representation of what they do. You can't adjust them though (at least from what I've tried).
