Sony walkman Tips and Tricks
Jan 14, 2018 at 4:10 PM Post #106 of 155
SAVING CUSTOM EQ SETTINGS
1. If your walkman has the DIRECT SOURCE set to ON, turn it OFF, then go to the EQ/Tone control Page (I'm using a NW-WM1A)
2. Mess with your EQ to your liking, the one i did is an example as it may look extreme. Once done editing the EQ values click complete on the eq settings.
3. Tap the SETTINGS Menu (Toolbox icon) then Tap saved sound settings. You are in the Saved sound settings options.
4. Tap the Save Current settings Button and the WHERE TO SAVE pop-up appears, choose one setting to save at (tap)
5. If the dialog prompt that tells you to replace the current settings pops-up, click OK
6. Your settings are now saved To retrieve them just Tap the saved sound setting 1, 2 or 3 (where you saved your cusyom EQ and other presets) and tey will load. If a prompt to overwrite current settings pops up, click OK to LOAD your SAVED SETTINGS
Thanks so much! That worked. For some reason it didn’t seem that clear to me.
Feb 25, 2018 at 4:45 PM Post #108 of 155
Jun 7, 2018 at 5:32 PM Post #110 of 155
From the dead I lift you.
All I’d like is a simple tool to sync my music library to my ZX300. Drag and drop is fine and all, but I have a ton of PDFs and Liner Note scans I don’t need to be on the player. I’d also like to not have to drag and drop my whole library every time I want to add stuff to the player that isn’t on there. The X-DAP tool for Pioneer and Onkyo players was simple and worked great, I’d kill for such a program to work with my Sony DAP. I don’t want it touching my metadata or anything, I’ve meticulously curated my library with Bliss and I don’t need Sony’s Media Center messing that up. Surely there must be a solution.
Jun 7, 2018 at 8:44 PM Post #111 of 155
I use MusicBee, now that MediaGo is no longer available
Jun 7, 2018 at 9:07 PM Post #113 of 155
Jun 8, 2018 at 9:46 AM Post #115 of 155
Does it handle DSF files ok, and can I trust it with not touching my metadata? If so, I’m totally sold.
Yes it handles my FLAC files, HR FLAC and DSF files ok
Jun 8, 2018 at 6:48 PM Post #116 of 155
MediaGo no longer available?
I'm still using it although it's a couple of weeks since I did
Jun 8, 2018 at 8:38 PM Post #117 of 155
I tried looking for it, to download it again, as i am gaving a hard time with Music Bee properly cataloging my HR files (it skips 24/44.1 and 24/48 resolutions. Aside from that MusicBee is a great manager
Jun 8, 2018 at 9:19 PM Post #119 of 155
I'm not seeing any support for DSF files. They don't show up in the app...
which version did you install?
Jun 8, 2018 at 9:23 PM Post #120 of 155
I have Music Bee version 3.1.6590. Did you download it from the windows store or from their website? i am using the traditional "legacy" desktop app, Windows 10
