for guys who used A10 with pha-3 : is there any sort of battery drain on walkman like the one in ZX1 with pha-3 combo? I've heard that ZX1 lasts for only 5 to 6 hours per charge with pha-3.
I think it is around 8-10 hours.
oh if so then it is damn low compared to 40 - 50 hours!
hey guys.. what do you think this sony dap vs ibasso dx50? same price, same quality? which one is better?
Who's using the Sony XBA-H3 with a A10 series walkman, and how do you like the match especially with classical music (instrumental and chamber particularly)? I'm currently using my A15 with some Hifiman RE-262 and the result is good, but I've never liked the signature of those in-ears...too mid-centric for my taste. I'm thinking to get the H3 but I'm a bit scared the bass could be too much.
Thank you both for the reply, much appreciated.
@gerelmx1986 i find the volume just fine with my existing in ears, nver goes over level 16, and I don't like my music very loud anyway. I'm not concerned about not getting the last bit of soundstage as I mainly listen to chamber rarather than orchestral music. Timbre accuracy is what I'm after, especially with strings. Your description sounds promising...I'm wondering if I'll able to try them in store with my music. I don't want to replace my home rig but I'm really enjoying usinfusing the A15 while commuting or even in bed.
@jmsaxon69 Are the A3 the same as the H3?
Bearded dudes, facial hair is so yucky. Each to their own![]()
