While other factors (coating, braid) also matters, conductor alone your statement "better bass slam" with copper is not accurate, IMHO. Silver plated copper cables tends to have a more V-shaped FR response, while pure copper have a more linear FR, or slightly mids (vocal) strengthened sound signature.If you seek a fun sound signature, I think the JVC wood series of iems offer that.
my ier-m9 is on stock cable which is sliver mixed copper. I believe you would get better bass slam with Kimber kable as its pure copper.
SONY NW-ZX500
Sonywalkmanuser
yup you are correct. The kimber kable would have better bass slam due to better current delivery/capacitances/etc from its bigger wires/better materials. I meant without silver on the kimber, it also means less treble brightness and overall a more mid centric sound on the IER-M9(which with its Super tweeter can sound bright on louder volumes and can use a little taming)
Mine just arrived. How do you guys burn it in? Charging it while keep it play music for hours?
Sonywalkmanuser
Be sure to use at least medium volume levels. I prefer to use random playback as it cycles through all different types of music and should allow the capacitors to work on a broader range music as compared to just playing one album on repeat.
Hi, using my ZX507 with an unbalanced cable Fiio FH7 IEM's. Does a balanced cable makes sense for better sound quality?
Current one: https://fiio-shop.de/en/cable/855/fiio-lc-3.5d
Balanced cable: https://fiio-shop.de/en/cable/856/fiio-lc-4.4d
Thanks in advance.
Thanks in advance.
Focux
On ZX507. DC Phase Linearizer Set to Type A High does make the IER-M9 sound closest to a punchy Dynamic Driver. In my opinion, It would require 250hours burn in on the balanced to get the kind of extremely deep sounding subbass and punchy bass on type A setting.
Was shockingly disappointed w the FW10000
innocentblood
I’m burning in mine while actually listening to it so that I can experience how the sound changes over the course of the next few months
gobb
- Feb 27, 2017
Thanks in advance.
I use thic combination, but with C-type cable, LC-4.4C. The combination is great, sound is wider than with standard cable.
Sonywalkmanuser
Tried the zx507 single ended as line in source for my Prius car sound system.
Although it's not a true line out. I must say that on high gain at 120, zx507 sounds really musical. DSEE HX effect also works inside the car, making things don't sound so enclosed instead now it feels like a mini concert hall with width, depth and height.
The first noticeable improvement I’ve observed is the sound staging. When I first turned the Walkman on and had a listen, music felt relatively one dimensional. But now after about 8 hours I’m starting to hear better layering and depth. Had this same experience with the WM1Z.I’m burning in mine while actually listening to it so that I can experience how the sound changes over the course of the next few months
Hi gobb, thanks for the info.
I will order it and report my experience!
BR
The ZX507 has plenty of power for the Z1R IEM’s. Volume 65 on high gain is about as loud as I can tolerate.
salanos
- Jun 28, 2012
Is that a screen protector on it? It's got a really obvious 'orange-peel' finish in that photo...The ZX507 has arrived. I really like it’s size - Light and compact. It’s nice to have a smaller device after a few years![]()
I'm currently stuck, looking for a new DAP...
Either i cave and get the ZX507 when it becomes available on amazon canada, or wait for the Lotoo Paw 6000.![Frowning2 :frowning2: :frowning2:](https://cdn.head-fi.org/e/people/frowning2.svg)
also, would anyone know how the Sony stacks up against my current DAP? (Astell & Kern SR15). thanks
Sonywalkmanuser
Total: 11 (members: 0, guests: 11)
