DanielListening
I formatted using the Android Software. That seemed to do the trick. LOL That is the best I have got.
Seriously, what a revelation!! I've been enjoying my ZX-507 for about a month or two either from my SD card or via Qobuz but the difference was night and day in favour of the SD card. Yet, a single streaming note coming from UAPP (Qobuz - Bit Perfect function turned on) was enough to set me ablaze; I knew how Qobuz files sounded from my regular setup, both stereo and hp, so it was ridiculous to see how limiting Android was with regards to SQ. UAPP levels the field no question; I say no Android player should be without it, especially for those of us who want to enjoy true hi-res quality from streaming!There is an Android music player app, USB Audio Player Pro. This app allows you to login to Tidal and play music from there bit-perfectly on the ZX500/A100 players. All other 3rd party apps are using a different audio path, the one that resamples the audio, while UAPP can play audio through the same audio path as the Walkman app, the one that doesn't do any resampling, the same one used by the Walkman player app.
The ZX500 series automatically formats the card in exFAT, also creating an Android folder for the OS and a Musiс folder for the built-in player on it.Which file system do you use (NTFS or exFat)?
If you think it's ridiculous I would not do it. You won't be happy either way. I also have the m11 and it's a solid dap. I have had no issues with it. Everything is personal preference.The fiio has an eq as well to personally tune correct? I have the ZX507 but for $200 less the M11 ltd has way more features then the zx not to mention android 10? i will have to give it a listen and send one back. The usb dac and car play is imortant. This my first dap with dac so i want to make the right decission and spending this $$ is ridic lol
no idead what AccessorJack is, i'm in canada the sony is just over$1000 and M11 ltd is like $850 i may just return the sony after i hear the fiio
