it's microsoft's fault. as it is their deliberate choice.
I hate windows for this reason.
a year ago I bought a new laptop.
and new version of realtek audio driver pissed me off.
no eq, and loudness normalization, sound disappears after waking up from sleep mode.
and u can't deal with all this issues by simply updating or reinstalling the driver.
dealing with eq problem leaves sound absence after sleep mode.
and after I spend a lot of time a few times (as this problem re-emraged a few time, after microsoft mandatory "updated" audio drives)
one problem still left. user has no option to select an input device.
in my situation it's microphone input.
when sony 1Am2 headphones (with micro in the 3.5mm chord) are connected, windows mandatory turns off internal dual microphone.
however later chord part of microphone in headphones died, and I can't symontenously use both headphones and microphone as current realtek version does leaves option to switch microphone input to internal one, when headphones with 4pin (microphone) 3.5 jack are connected to laptop.
in series of drive updates and reinstalls, the option of selecting microphone input emerged, however, no eq, loudness normalization, and sound absence after waking up from sleep mode.
eventually after particular sequence of reinstalling some version of driver and updating it in particular driver udpater software I have both eq and no issue with sound after sleep mode. however still I can't select input microphone.
to deal with microphone issue, I bough:
— 5m 3.5 (3pin)male to 3.5 (3pin)male cable.
— 3.5 to 3.5 female adapter.
thus I connect 3 pin (with out pin for microphone) to laptop, and via 3.5to3.5 female I connect my headphones with3.5 4pin (microphone) plug.
that's how I can use both headphones and internal microphone.
prior to buying a chord and adapter, I used wifi and old iphone as a microphone. additional soft created option to select microphone input between wifi(iphone) and realtek (internal or 4pin headphones)
a lot of headache thanks to microsoft
