@ttt123 have you updated to the latest firmware?
If so, do try these modes on Walkman music app:
1. Hi res streaming Off, direct source On
2. Hi res streaming Off, DSEE HX On
3. Hi res streaming On, direct source On
4. Hi res streaming On, DSEE HX On
Each of these mode has its own unique sound. I can't decide which is better. I would like to know your opinion on which you like best.
Updated to the new FW, and applied your optimization settings, and tried the 4 configurations. Just a quick try, using: In The Garden-Van Morrison.
- I still prefer this mode. There is an interplay of the different elements of the music that is present, that is lessened when DSEE HX is turned on, which seems to flatten the sound. I suspect this is more observable with acoustic music, with more natural mastering, which preserves more micro detail. With electronic or highly processed music, may not be able to tell any difference.
- Both mode 1 and 2 are musical, and I think both are better than the old FW It still feels like micro dynamics have been smoothed out, though sounds better than with the old FW. (and relying on memory, of course) Perhaps a side effect of the processing that makes the sound more forward and clear. Maybe the clarity is like the trade off in a photo, when more sharpness is applied. You gain something, at the cost of something else.
- Both mode 3 and 4 sound very similar. It seams Hi res on affects both Direct and non Direct mode. (I never tried with Hi res streaming on in the old FW)
- Both mode 3 and 4 sound very similar. The difference with DSEE HX on is not that great.
So the above is my observation. For my system, and the type of music I mostly listen to, Direct is my preference. Thanks for getting me started to take a closer listen, as I had not previously done that. I did enjoy both Direct and DSEE HX modes, and had not bothered to see if one was better in some ways, and/or if I might actually prefer one over the other.
