Sonywalkmanuser
Just wondering if keeping the ZX507 charged up with 100% is better than allowing the battery to rundown from 100% to 20% before charging.
So leaving it plugged-in for long stretches of burning-in is not so great for the battery? I was worried about that.....as I was doing it anyway, LOL. I am just barely over 200 hours now on both 3.5 & 4.4 outputs. On both, probably 65-70% of those hours were when it was plugged in for burning-in purposes. As I am over 200 hours on both outputs, I am done with that routine, however.Staying at 100% will degrade the battery. Lithium Ion nominal voltage is 3.7v but when fully charged is 4.2v, this put's stress on the battery. There is nothing wrong with running down the battery, it's only when you go below maybe 20%-30% that the voltage drops below 3.7v which is also not great for the battery. For best longevity I try keeping the battery between 30% and 70%, but even between 20% and 80% is fine. Once a month or two I do a full charge and rundown to calibrate battery and eliminate trace memory (not really a problem with li-ion though).
I think I'm convinced that bass got slightly tighter with improved detail; detail retrieval above 2k improved; perhaps a bit wider stage. How I did it on both outputs was a burn-in track played on repeat, high gain, vol at 55; anywhere from 12 to 20 hours straight. Then I unplugged it, turned it off for several hours, then used it for regular playback for several hours (unplugged), then back to plugged in burn-in.Did you notice any sound changes after 200hours?
Also if you have not done this:
Finally arrived. Thanks for the tips everyone. Updated the FW, changed to hi gain, hi res streaming. Downloaded the apk for Xiami and QQMusic, and downloaded Tidal and Spotify. And we are ready to go!
Here is my setup for the battery. It might be good for you depending on your regions and regulations. The USB C cable has to be short like 4 inches. So I don't have loose cable hanging out. The strip will glue the player and the battery together. I will never worry about battery life anymore.
And now, despite it’s superb shootout performance, I am even more frustrated with my ZX507. Remember, it was hamstrung throughout due to it’s inability to convert streaming MQAs... And it still won every sound quality category. Imagine how it would have done if it was able to properly play those tracks.
