psikey
- Jul 15, 2008
I’m seriously considering the zx507 as a true upgrade to a Shanling m0. I only use IEMs. I primarily listen to music via my flac collection on a large capacity sd card, so streaming is just a bonus. The reason I’d go with the 507 over the 105 is the better battery and the reason I’d go with the 507 over the zx300 is the audio quality is supposedly far superior on the 507 (plus usb-c).
Can anyone confirm it’d be totally fine to buy the zx505, since it can be bought new cheaper? It’s just a matter of changing language from Chinese to English, correct? No other differences?
Also, Sony’s firmware support is typically really solid and lasts for years, right? Should only expect improvements, additional features, etc?
Lastly, has anyone used an Etymotic IEM with the 507? How’s that pairing? I have and really enjoy the er2xr. Thank you!
The A105 actually has slightly better battery life than ZX507!
Pick ZX507 if you need balanced and the extra power. The ZX507 is noticeably better than A105 if using balanced but similar if using SE.
Its Android 9 so should be supported for a while. ZX505 if you want to mess with firmware and likely no warranty support (unless in China).
