Andricop
- Nov 12, 2010
Hey, can you tell me how you were able to do this? I bought the ZX505 secondhand and then made the mistake of performing a full reset. Everything has reverted back to the original Chinese language interface and I can't navigate thru the player. I'd like to install English firmware as well enable the Play Store. From what I can tell the only way to update the firmware is via Wifi or Music Center for PC, but Music Center isn't detecting any updates. (I'm guessing that for the Chinese firmware, the player is up to date).
~edit - OK, just had to navigate and find the language settings; was able to get into the English interface.
Would still like to install the English firmware to access the Play Store. Any help would be greatly appreciated.
Sorry for my late response, but the new HF website does not send notifications properly anymore.
Download one of the following file and copy it to the root of the player and launch manually the firmware by going into settings-> system->advanced->system updates (if I remember correctly)
China (no PlayStore)
https://info.update.sony.net/PA001/...ents/0002/NW-ZX500_0003_V1_10_03_NW_WM_FW.UPG
Japan (PlayStore available but also other Japan only software)
http://info.update.sony.net/PA001/N...ents/0002/NW-ZX500_0001_V1_10_03_NW_WM_FW.UPG
Europe ? I'm using this one, PlayStore is available
http://info.update.sony.net/PA001/N...ents/0002/NW-ZX500_0002_V1_10_03_NW_WM_FW.UPG
? not tested
http://info.update.sony.net/PA001/N...ents/0002/NW-ZX500_0004_V1_10_03_NW_WM_FW.UPG
? not tested
http://info.update.sony.net/PA001/N...ents/0002/NW-ZX500_0005_V1_10_03_NW_WM_FW.UPG
If someone knows exactly to which region apply each version of the FW please share! Thanks
