Partlys4int
- Jul 12, 2015
I like them natural: boobs and musicI personally love the enhancement options.
At the current moment, the player only supports MQA when played back as a file on the player directly. When using the player as a USB-DAC MQA wont be decoded.Has it been established yet whether the ZX300 can fully decode MQA files when either streaming Tidal Masters files or downloading/caching Tidal Masters? There seems to be number of mentions of MQA on this thread, but no definitive answer.
I’m keen to purchase a high end DAP, but only if it fully supports MQA.
Not as saved files perhaps it's not better/worth it, but from what I've read it is really nice for people who stream their music. It's like Hi-Res that can be streamed in an efficient manner, or almost.At the current moment, the player only supports MQA when played back as a file on the player directly. When using the player as a USB-DAC MQA wont be decoded.
Just to make sure MQA isnt something people should buy into, it adds DRM to music. Also its lossy and its bigger than a equivalent in normal FLAC. Also the added DSP doesnt improve audio quality. Please look into it more and I guarantee you that money will be spend pretty much everywhere better than on MQA.
The difference is relatively big. If you listen so little time, I'd let it play overnight. Sure it affects the battery a little, but you can just pop in any headphones you don't deem important.How do you guys like burn it in? Playing nonstop overnight or so? Do the iem’s have to be plugged in appropriate plug? Is that enough? With my tempo just through listening, i would be close to 200 hours in a couple of years. Isnt it wasting of battery, iems? I cant judge what would be the difference in sound.
Nice pictures!205H burned
ready to rock...
I like the way the black colour changes from deep charcoal to deep black, depending on the lighting conditions. And it looks smaller compared to the silver, just an illusion but still.The silver one does look nice, it was a hard choice between the black or silver, but it was the Black for me, but both look nice in their own way.
I think the Black one just has that professional look.I like the way the black colour changes from deep charcoal to deep black, depending on the lighting conditions. And it looks smaller compared to the silver, just an illusion but still.
If I had to choose again, I would pick black every time. Although, if the black would not exist, I would have been much pleased with the silver too!![]()
Agreed! It's rather inconspicuous aside from the gold/copper-toned outputs. The sort of device that you need to look at from a little closer to see its premium built. The silver one is more eye-catching, in the sense that you can tell more immediately that it is an expensive device.I think the Black one just has that professional look.
