its not. the pcb connects those two connections later on the board. sony does it becaus they claim it gives better seperation but its connected to the same point.I see the ZX300 only has 3 connectors on the PCB so TRRS is not possible, but the WM1A and 1Z is individual grounding.
Sony NW-ZX300
PCheung
- Nov 25, 2016
Thats wrong. The WM1s have TRRRS and TRS. Also the sleeve isnt wired up on the TRRRS. TRRS means either balanced or remote compatible. You can look up intern pictures for this information.
The WM1 should have TRRS 3.5mm jack same as ZX2?
as other members who owned ZX2 used their old earphones with TRRS plug on WM1 and it works
obvsly it works since the wiring is the same but its not balanced lol its the same shared ground. its like connecting 2 wires to one ground vs a y wire thats connected to one ground and later split up.The WM1 have TRRS 3.5mm jack same as ZX2
PCheung
- Nov 25, 2016
Who say it is balance?
TRRS 3.5 never a balance out since ZX2
the guy before said its balanced but there is no difference lolWho say it is balance?
AudiophileInTokyo
Currently, I'm the happy and very satisfied owner of the WM-NW1A.
Initially I wanted to get the ZX300 too, but on second thought, I'm not sure I will do so. What for? WM-NW1A boasts a slightly better sound, and sound quality should be the priority. So for the majority of people who already own one of the WM-NW1 DAPs, it doesn't really make sense to get this....
However, I'm still torturing myself trying to decide whether to get the WM-NW1Z.
kms108
- Jan 27, 2012
I have never said it's balanced, just TRRS separate grounding which does improve SQ slightly.
it doesnt and by definition, separate grounding means balanced. Show anything that proves that just the fact that ground is separated improves SQI have never said it's balanced, just TRRS separate grounding which does improve SQ slightly.
kms108
- Jan 27, 2012
Separate grounding does not mean balanced
By definition, a Balanced signal means that the ground of each is not shared => separate grounding from DAC to Headphone means Balanced. Tell me what you think is balanced. You can literally give it a quick search lol It seems like you have no clue lolSeparate grounding does not mean balanced
goody
- Apr 2, 2009
i will pick up a second hand WM1A if i can
- Oct 14, 2013
Are you the engineer behind Walkman? How can you claim that they shared grounds when Sony said they are separated ground. Do you know how SMaster is wired and engineered ? It could just be the 2 separated negative signals wired directly from SMAster itself and Sony can not claim that it is balanced because there are no inducted coils to further amplify the signals.obvsly it works since the wiring is the same but its not balanced lol its the same shared ground. its like connecting 2 wires to one ground vs a y wire thats connected to one ground and later split up.
Unless you are thinking that you can simply connect a 3.5mm positive and chassis ground for negative and get music from it...go ahead...try it. Chassis ground is different from Signal ground ***
Never said I know anything better than Sony. Sony themselves dont claim its separated ground lol They say its shared, but they claim that the separation till the AMP gives it better "audio separation". Just look it up man. Also I never said anything about there S-Master system. I dont wanna create a stupid discussion, they ground is shared on the SE output and thats fact, ask the Sony Support/Engineer or who ever you want that actually works or knows how the PCB is laid out. One more way is to just use a multi meter and check if it is shared and it is.Are you the engineer behind Walkman? How can you claim that they shared grounds when Sony said they are separated ground. Do you know how SMaster is wired and engineered ?
- Oct 14, 2013
Link it up to me, perhap you are talking about Zx300 and not Zx2. Sony claimed ZX2 had “Separated grounding” on the uses of 3.5mm TRRS
I am not even speaking about any of those, I am speaking about the WM1A and WM1Z. I dont know anything about the ZX2.Link it up to me, perhap you are talking about Zx300 and not Zx2. Sony claimed ZX2 had “Separated grounding” on the uses of 3.5mm TRRS
Total: 13 (members: 0, guests: 13)
