kms108
- Jan 27, 2012
some do end up in taobao and ebay, you just have to look around for them.
More detail and musical than my LG V20 with wired and wireless. Greatest difference is when wired as the ZX300 must have a better amp than the V20. But given the V20 is only about £300 it is a bargain DAP.So, must be a few in owners hands now so what's opinion compared to other Sony players inc ZX2 and the expensive ones, also interested comparing to Mojo; DFRed; AK & Fiio players; LG V30
Honestly while driving iems, i have always felt that the A35 was adequate (even without high gain).
Si signor, if you check under output settings.Oh yes it drives most stuff very good, but the other daps I mentioned have more headroom and will drive 300 ohm cans pretty good. Is there a hi gain setting on A35?
And a35 is a real cracker if you don't have any naughty hi ohm cans, great sound, great price, and small with better than average battery life.
I have never ventured there as the default settings were always adequate for the iems i have. Looking at the brighter side its there, whether i use it or not is secondary. now you have something to play around with till you get the zx300Well I'll be dammed, I never knew that, well time to cancel my zx300 order ha ha I doubt it will drive my senns but I'm going to check it out.
No idea about the A35, I checked the A40 series while I was at Yodobashi and it does not have a high gain setting.Si signor, if you check under output settings.
I tried the USB DAC feature with my Galaxy S7 edge and the WMC-NWH10 cable and that failed. Perhaps another cable is required.
