animalsrush
- Aug 15, 2005
time - it takes like " a day" to transfer more or less 300 files.... it use to take 30minutes..
and its easier to delete albums etc... it is a late 2013 mac 2.7ghz i5, my music files are in a different hard disk...
anyway it was faaaar faster with content transfer
am i the only one?
Wow. That is way too long .. I have transferred about 15 GB in about 4 mins.. The one thing i have noticed in Mac if you open parallel copies it takes longer . My suggestion would be to copy all files in a single move .. Normally the way do it is .. I use CMD + Select file folders i need to move and move it on the player first in a common location on the player ( if they belong to different directories). This moved files faster. Once loaded on the player move them to the correct folders as you need. If you are moving folders new it is even simpler. Also you can overwrite or merge destination folders .. My advice copy all music in one shot and see if that improves performance
PS : I use macbook air 2012 version with i5 1,7 ghz processor so definitely slower than yours
