SONY NW-ZX2 DAP
post-15202755
Post #14,461 of 14,580
BanC
South Korea
South Korea
trrs is not placebo , i had my cables done into trrs when i owned the zx2 (and i also did them into 4.4 now that i have moved on to the wm1a)
btw , i have a TRRS 2-pin cable for sale , selling it for half price and in like new/mint condition with zero usage , since i moved into the wm1a i am not using it so it has to go to a new loving home
https://www.head-fi.org/threads/forza-audio-hybrid-2-pin-3-5mm-trrs-ciem-cable-for-use-with-sony-ΖΧ2-wm1a-wm1z-zx300-cowon-p1-hifiman-901.863115/
cheers
I also think that it's not a placebo. I have a few cables of mine re-terminated as 3.5 TRRS. The improvement in sound quality is very surprising, although we need to keep in mind that this could also be due to the quality of new plugs (I use Oyaide rhodium 3.5 TRRS plug). Instrument separation becomes a lot better. Imaging also improves. Specifically it becomes deeper but not wider (which is a huge different effect from 2.5 balance as 2.5 balance tends to improves soundstage width). I would say that overall the improvement is very rewarding. The only issue that marks a major difference from typical 2.5 balance and 4.4 balance is the absence of improvement in driving power.
Reactions: proedros
post-15203078
Post #14,462 of 14,580
kms108
I also have a sony 7N cable with a pentaconn brand 3.5 TRRS plug.
Definitely a improvements over the normal 3.5mm.
post-15203720
Post #14,463 of 14,580
BanC
South Korea
South Korea
I would even go farther to say that I prefer the effects of ZX2 TRRS over the effects of 2.5 balance on my Onkyo Granbeat as well as 2.5 balance output in general. 2.5 balance tends to increase soundstage and cause notes to be thinner. This leads to sound that has less focus.
post-15220980
Post #14,464 of 14,580
Satchamoose
United States
United States
Frankly, I wouldn't worry too much about the longevity of the battery.
https://en.m.wikipedia.org/wiki/Lithium-ion_battery
Typical wear for a Li-ion battery is that it will be reduced to 80% of its original capacity after 500 recharge cycles. It's important to note that they mean full, complete recharge cycles--from 0-100%. If you typically recharge the battery when it reaches, say, 20% remaining power, and you charge it back up to 100%, then that's only 80% of a full discharge cycle.
In my case, on average, I recharge the ZX2 once every 10 days. And by that 10th day, I am indeed at approximately 20% remaining charge.
So that's approximately 36 recharges per year. And realistically, that's only roughly 29 FULL recharge cycles per year, since I'm only recharging 80% of the capacity each time.
Round that up to an even 30 per year, and it becomes obvious that it would take about 16 years for me to reach 500 complete recharge cycles. At which point, the battery would STILL contain 80% of its original capacity.
Of course, the simple march of time would probably speed that number up. But it's still safe to say that one shouldn't notice any appreciable degradation in battery life after two years. And likely, not even after five years. By that time, we'll all have moved on to our solid gold NW-WM1Zs anyway. Amirite? :D
Can anyone tell me whether there is anyone in the US who can replace the battery? Thanks.
post-15221012
Post #14,465 of 14,580
kms108
post-15223373
Post #14,468 of 14,580
BanC
South Korea
South Korea
I can't find any Sony website, phone number, or email address that deals with the ZX-2 anymore. If you know of any, I'd appreciate it.
No. I don't. I actually don't live in the US. But I would assume that if you call to Sony's call center they should be able to take care of it?
post-15223697
Post #14,469 of 14,580
BanC
South Korea
South Korea
I found the phone number for in-warranty repair (link). I think if you call them you could ask information about services beyond warranty.
post-15230338
Post #14,470 of 14,580
studiorat67
CT
CT
I have a question, for you folks,
allow me to preface it with this:
I know the WM port passes audio, HI res only but its limited to UDA-1 compatable amps, according to Sony;
so that pretty much leaves out everything but the Fiio Q5S, and a few others..
I have several Fiio amps the E18, A5, Q1 MKII, And Q5s but they are useless with my Sony except q5s ...
My question is Does the line out single end cable Pass the same hi Res as the WM port??
and if yes will. my Amp be able to display the correct color code on the led for different file formats as it does with my M11
post-15281973
Post #14,471 of 14,580
Coldeign
Germany
Germany
Has anyone loaded amazon music 6.1 apk and checked if it allows amazon music HD playback?
(last apk before 4.4 became a minimum requirement)
Interesting Q&A with regard to the zx500/507
"Is mqa support via the installation of the tidal app on the device? if so can albums or playlists be downloaded for offline listening?
Answer:
Hi,
The Walkman doesn't support installing apps, however the MQA file format is supported.
Sony support team"
So that means no installing 3rd party apps...
Installing apps (.apk) is possible (qobuz is running almost smoothly on an older version). However newer versions of amazon music are not running (error #FN30).
post-15371591
Post #14,472 of 14,580
saveanimals
San Francisco, CA
San Francisco, CA
Can someone tell me if Qobuz is still crashing all the time on this DAP in December 2019? Reading many things online and seeking clarity. Looking to get this for Qobuz offline mode only.
Should I buy it if I want it for Qobuz offline?
post-15416801
Post #14,473 of 14,580
DONTGIVEUP
5 and a half years later price has gone down to $300 from a formidable $1200 price tag.
WOW!
Might as well get rid of my 1A/1Z now before it goes to the same value in 2 years.
post-15416940
Post #14,474 of 14,580
Infoseeker
Michigan, Detroit Metro Area (currently in Qatar)
The 1a 1z won't devalue as much because they don't depend on an operating system.
That is why the Calyx M dap has aged well since its release.
Reactions: Virtu Fortuna
post-15418893
Post #14,475 of 14,580
SebaE2012
WOW!
And still, while a bit outdated for streaming services and other details it's still a formidable piece of kit. Terrific battery life. Great, detailed yet-well-rounded sound. I'm still enjoying it a lot with my growing collection of hi res and my 16/44 flac files ripped from CD.
I was thinking about updating it and getting a ZX507 (I did some research on other daps, Fiio M11, Cayin N6, etc), but as I see it, the ZX507 is on a tier below in the Sony line... Tempted, but still waiting to see what the replacements for the WM1A/WM1Z might be. The ZX2 will soldier on for a little longer here. No hurries.
