SONY NW-ZX2 DAP
post-15067239
Post #14,446 of 14,562
lukedss
Also worth noting that I think through UAPP it will play MQA files from Tidal. Its showing 24bit when playing..
post-15067274
Post #14,447 of 14,562
kms108
Thank you for the reply.
I've just bought a used one.
I've succeed install only spotify using those method. And for tidal when tried to install for 4.2.2 apk tidal there was an error "parse error - the was a problem parsing the package" i have no idea this error.
By the way how long the baterry last on used ?
Mine is only about more or less 10 hours.
Is it normal considering a used zx2 ?
And is theres a way by any chance to replace the battery ?
Thank you.
on a used one, it depends.how long it's been used before. you can change it at Sony.
post-15067345
Post #14,448 of 14,562
cfc7
Bucharest, Romania
Bucharest, Romania
I asked my friend about the battery and he said its normal if the battery could last 10 hours.
But its a bit wierd that at sony official spec cpuld last 33 hours on hi res.
I've only set brightness about 1/4.
Bluetooth off but wifi on. Played hi res flac.
If its normal about 9-10 hours, i quess its okay then.
I will try the apk from the one you used.
Once again thank you for the help and for the quick replied.
How old is it?
Try to use the airplain mode when you're not streaming and minimum brightness.
For the battery you can try in a Sony service.
post-15069553
Post #14,449 of 14,562
Starlights
Jakarta
Jakarta
sorry, i dont understand what is UAPP ? is it USB Audio Player Pro ?
thank you
i had no idea how long the user before me has been used.
and i doubt sony official in my country will have the sparepart battery but i will ask them.
thank you for the idea.
How old is it?
dont know how old, i've just bought it used. and i think the owner before me dont know either.
today i've tried using different applikasi like jet audio/netutron played hi res songs, and i think the battery long lasted than the deafult app audio which has existed.
8 hours straight from 100% to 31%. with brightness 1/4 using bluetooth to BTR3 until the battery BTR3 drop off and wifi on.
do you guys think the battery still normal ?
i have found this link :
https://encompass.com/item/10861102/Sony/X-2591-264-1/
is it legit ? and can be use for zx2 ? anyone knows ?
thank you
post-15069558
Post #14,450 of 14,562
kms108
try Sony service center.
post-15069644
Post #14,451 of 14,562
Starlights
Jakarta
Jakarta
post-15069739
Post #14,453 of 14,562
lukedss
Yup that's why i shared my observation, Davy asked me about a colour showing when playing MQA on the ZX2 so that he can confirm if it is playing MQA so i need to get back to him about that
Reactions: 329161
post-15071723
Post #14,454 of 14,562
Starlights
Jakarta
Jakarta
https://ibb.co/P65PBcL
Anyone knows what version my zx2 ?
To me just like the chinese version.
Is there a difference between any other version ?
Maybe the good one version or the bad.
And anyone knows where can i buy the tempered glass for this ?
Thank you
post-15133991
Post #14,455 of 14,562
Sheep_
Do you guys use any program to easily create playlists on the ZX2? If so, could you please recommend them to me
post-15146499
Post #14,456 of 14,562
Richter Di
Germany
Germany
Age
54
Website
pilates-powers.de
I use the Sony app for creating playlists. It works fine.
post-15174708
Post #14,457 of 14,562
Silvano
Bolgheri (ITALY)
Bolgheri (ITALY)
Age
57
post-15176664
Post #14,458 of 14,562
proedros
Athens , Greece
Athens , Greece
new sony dap with android coming up
zx500
post-15176923
Post #14,459 of 14,562
josephtym
singapore
singapore
zx500
the zx500 got most what i want:
1) a current android OS that will have no issues with spotify storage
2) able to use streaming
3) usb c for fast charging
4) balanced output
the only thing that holding me back that it is not the successor to the wm1a.
post-15194938
Post #14,460 of 14,562
Doug2507
UK
UK
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
