Bengkia369
Can this Sony remote works on my AK240?!
That remote- although handy if you own one of the brickweight WM-series- is a little bit ridiculous no? On the website they promote it to use it while your 'portable' media player is in your backpack lol
True, but unless a 3rd party option becomes available what can you do?
I think it's heideous.
First imagine oneself holding the remote in a public place while the player is in your pocket.Could be a cause of concern for a few.
Second ppl may think your crazy holding a 1990s remote in your hand.
Sony should have come out with a better remote like the one that came with the discman D-EJ01 or should have come out something similar to the size of an iPod nano.
What walkman line out cable is that and where did you get it please?
one of the best looking remotes for. Me is the fiio oneI think it's heideous.
Sony should have come out with a better remote like the one that came with the discman D-EJ01 or should have come out something similar to the size of an iPod nano.That remote- although handy if you own one of the brickweight WM-series- is a little bit ridiculous no? On the website they promote it to use it while your 'portable' media player is in your backpack lol
Hey guys, i'm new to this forum and about to buy the NW-ZX100 but just need a question to be answered.
What about the so called "EU volume cap" some of you talked about? Is it just the AVLS option (that can be turned of in general settings, atleast in an older NWZ-E474) or infact a plugged in feature to annoy/protect european listener?
Thanks guys!
Ok, i got you. I thought i could save some bucks on that way. So, would you recommened the asia pacific version then?
I found this device for around 400€ and they told me that it is intended for the japanese market but comes WITH volume limit. Maybe AVLS then?
yes i recommend you the asia pacific version, i plaed mine with 32-ohm load XBA-Z5 at vol. 10 of 30
