SONY NW-WM1Z / WM1A
Status
Not open for further replies.
Jun 1, 2017 at 2:31 PM Post #12,377 of 45,723
But with a 3.5mm trrs going in that port, I've read that you get native dsd. I just want to know if there'd be much difference in sq when using the 3.5mm port (balanced) when it's being fed to an amp
No. Native DSD is only from the 4.4 balanced port. The 3.5 port is single ended or seperate ground, not balanced
Jun 1, 2017 at 4:22 PM Post #12,381 of 45,723
Eidolic makes a high-quality 4.4 TRRRS plug.
Jun 1, 2017 at 4:45 PM Post #12,382 of 45,723
Sorry for the extra question, but if I were to take a 2.5mm trrs and use a 4.4mm trrrs adapter, to input that into the balanced port, would it then be playing native dsd?
Yes anything coming out of the 4.4 is balanced as long as there are 4 wires (2 for each channel) all the way and wired correctly
Jun 1, 2017 at 4:46 PM Post #12,383 of 45,723
Jun 1, 2017 at 5:50 PM Post #12,385 of 45,723
Amazon US shows three variants to fit the Sonys. I just ordered the new glass version. Dealer is in Germany, so it might be a while before I get it.
It will arrive quicker than you think. 5 days from memory - this was the delivery time from someone else in the US who bought one. All the Brotect films come form the one German supplier who is either the manufacturer or seems to be doing global distribution direct from Germany all by themselves.
Jun 1, 2017 at 6:21 PM Post #12,387 of 45,723
I was the one who first reported on this. Cheap as chips - I bought two and they arrived in less than a week. Absolutely stellar
Jun 1, 2017 at 6:58 PM Post #12,388 of 45,723
Female or only male ?
I have a custom balanced cable from Double Helix Cables on the way, with male Eidolic 4.4mm and male Eidolic 3.5mm, for my Oppo PM-3 and the Sony NW-WM1A. Check his website for a great selection of parts and outstanding built-up cables.
Jun 1, 2017 at 7:01 PM Post #12,389 of 45,723
That's good news! Thanks. I have a Dignis case ordered, too.
Status
  • Back
