SONY NW-WM1Z / WM1A
Discussion in 'Portable Source Gear' started by leylandi, Jul 30, 2016.
815 816 817 818 819 820 821 822 823 824
826 827 828 829 830 831 832 833 834 835
  1. kubig123
    These Furutech plugs are a work of art!
  2. jamato8 Contributor
    Yes, most all my plugs are the Furutech. The RCA's for my desktop amp male and female, though expensive, are all that I use. The only plug I feel is a let down is the 2.5 TRRS because the center pin is steel and I have other TRRS 2.5 that are not steel and non magnetic and they hold up very well.
  3. Whitigir
    Yeah, I actually like Furutech for their Materials purity, I careless about it appearances though
  4. mw7485
    Can't recommend the Brotect products enough (Check amazon.co.uk). Cheap, well made, and a breeze to apply. I use them on all my screens.
  5. starblue
    Hi guys,
    I just bought my NM WM1Z in Japan. Its international version. How do I check if its EU version and/or volume capped?
    Thanks
    Blue Star
  6. blazinblazin
    I dont think Japan sells EU version.
    From what i read from this forum. Normally EU set have their options to check high gains locked.
  7. Toolman
    Was just about to type the same answer...most, if not all are Made in China. I picked up a couple in Japan then later another one locally at near half price all are about the same quality, and yes Chinese made. The only difference are the packaging and the branding outside the box.
  8. soundkist
    I have this one, and think it is fantastic; I ended up getting it from a recommendation a while back in this thread, so I think others have it too.
  9. alvinls72
    Hi All, first post here.
    I recently acquired the WM-1A and have been using standard earphones (ONKYO E700M) every since. Will there be a significant sound difference for BALANCED output?
    If yes, what balanced earphones do you experts recommend me try out?
    Thanks in advance.
  10. kokmeng
    Greetings.
    I have a quick question on WM1A burn in. Do you let the DAP run with power adaptor on? Or you run on battery & charge when it is needed?
    Appreciate your comment on this. Cheers.
  11. Smousesme
    Hi guys, I'm looking to amp my wm1a and I'm wondering if it matters wether I use the trrrs output, or use the trrs output.
    I know that using either will enable me to listen to native dsd, but will I be missing out on anything in terms sq for not using the 4.4mm output?
    Thanks
  12. gerelmx1986
    I reached finally 500 hours on my A, like it the SQ of balanced, since today I won't care if f the unit reboots
  13. PCheung
    native dsd decoding only on 4.4 balance output as I recall
    DSD convert to PCM on 3.5 SE
  14. soundkist
    I powered it via the battery, and charged when necessary. I don't know if the resulting trickle charge of using the adapter constantly would have any impact on such a modern battery.
    kokmeng likes this.
  15. JML
    Amazon US shows three variants to fit the Sonys. I just ordered the new glass version. Dealer is in Germany, so it might be a while before I get it.
