SONY NW-WM1Z / WM1A
Discussion in 'Portable Source Gear' started by leylandi, Jul 30, 2016.
814 815 816 817 818 819 820 821 822 823
825 826 827 828 829 830 831 832 833 834
  1. animalsrush
    Sony wm1z + z1r ..
    Love this combo.. use it at home while use k10 when traveling.. with Sony kimber balanced cable and z1r the synergy with wm1z is amazing. It sounds so smooth and refined I love it..
    Pc
  2. JML
    Anyone have issues with makes/models/sizes of microSD cards? I was thinking of the SanDisk Ultra 200GB Micro SDXC Memory Card; the 256GB are significantly more expensive.
  3. Toolman
    I am using the Sandisk 200GB microSD card with my WM1Z...and it worked perfectly :thumbsup:
  4. blazinblazin
    It's purposely designed to have some play on both port.
    Don't worry it's not the connection loose but its the whole female jack its not mounted on a solid board but only connected to the board by wires.
    Probably don't want to cause stress on the female ports.
    I would think Sony put in all their efforts to make this a long-lasting player.
    [​IMG]
  5. iamdman
    Makes sense. Thanks for confirming the same. Since none of my other players had that play I wasn't sure.
  6. kms108
    Try this, just search online for a taobao agent to help purchase this item for purchase outside of China.
    3.5mm male to 4.4mm female adapter
    https://item.taobao.com/item.htm?spm=a230r.1.14.176.jjx1oV&id=552149158294&ns=1&abbucket=10#detail
    https://item.taobao.com/item.htm?spm=a230r.1.14.110.NfxCne&id=551266289367&ns=1&abbucket=10#detail
    many 4.4mm male to 3.5mm female adapter
    https://s.taobao.com/search?q=3.5转4.4&imgfile=&js=1&stats_click=search_radio_all:1&initiative_id=staobaoz_20170531&ie=utf8&bcoffset=7&ntoffset=7&p4ppushleft=1,48&s=0
    musashino LABEL more expensive buying from here
    https://item.taobao.com/item.htm?spm=a230r.1.14.168.jjx1oV&id=551191840459&ns=1&abbucket=10#detail
    Not too sure if everyone is after this part, but the detail seems sketchy, so anyone with better chinese, please enlighten us the details.
    https://item.taobao.com/item.htm?sp...6865562215538536793.17.zhvpnP&id=551368655622
  7. Whitigir
    Wonderful, so China is already pouring out the female 4.4mm ? That is excellent, though the quality maybe doubtful but it is a wonderful news. I can not wait for Furutech to come out with a good solid 4.4mm male and females
  8. PCheung
    Furutech announced the 4.4 male plug, waiting for the female
    http://www.phileweb.com/news/audio/image.php?id=18729&row=3
  9. Whitigir
  10. gerelmx1986
    I reached 500 hours, and I want to update my review, but there's is no my reviews link on my profile
  11. Acemcl
    i am using the samsung evolution 256GB card and it worked without a hitch
  12. Acemcl
    Does anyone have any thoughts / experience using the following screen protector? I can have one sent by a friend in Tokyo
  13. jamato8 Contributor
    I asked Furutech about a week or two ago if they were going to make a socket in the 4.4 TRRRS form and they said no, only the plug. I hope they change their mind about the socket.
  14. hung031086
    Any recommendations on glass screen protector?
  15. kms108
    For my ZX2 i used benks and gamas, used them for a long time, there are many other brands available from ebay, aliexpress and amazon, but do notice which ever you buy the chances are, they are all the same or similar OEM rebadge and all made in china with different packaging, so just get the cheapest one. You may not be able to get the benks or gamas, as I will get the from taobao china unless you use a taobao agent.
