Lemieux66
I am tempted to buy the WM1A so badly :X but I only got WAV files, and also planning to get a CIEM with it, it's gonna cost a bomb haha!
You could convert your WAVs to FLAC.
Moon-Audio has Pentaconn:
https://www.moon-audio.com/4-4mm-pentaconn-balanced-connector-for-sony.html
One more box for me....Tidal support in Wifi mode.
i thought wm1a does not have tidal
$30 and a further $30 shipping !!
Any other suggestions ?
International shipping?
So you guys import the gold model from UK as is cheaper,but capped?
I know that it can be uncapped quite easily,but how big is the price difference between the capped model from UK and uncapped one sold in US?
Yes, it is balanced 4.4mm and I made it for me. This cables is the most expensive that I made for myself, yet.
where you source the 4 ring plug from?
thanks
Hi all. I'm currently using the Toxic Cables Silver Widow terminated with 3.5mm rhodium plug.
Would i be able to enjoy the full benefits of the WM1A's 4.4mm balanced output by re-terminating the Silver Widow cable using a 4.4mm balanced connector?
Or do i have to buy dedicated balanced cables (if there's such a thing)?
Sorry for the noob question. Thanks!
some one told me if zx2 was not in my taste, LOL no becausr it has Android on it for that i have a smatphone
So far WM1A has ticked all my boxes
- Firstly THANK GOD, Composer search
- Non Android
- simple to use GUI
- Great battery life and Power
- at least 128GB + expansión
- Realistic sounding (awesome soundstage, clarity, details retrieval, smooth silky musical sound)
- Great Build
- Touchscreen + side (or top like X1060) Buttons
- Delete music files on the fly
- Smooth volume operation (not abrupt increases like previous walkmen that had only 30 volume steps)
- Better (more responsive) EQ
- Ability to see both MicroSD and internal storage at the same time when connected to PC
