T.R.A.N.C.E.
- Mar 24, 2010
Not picking your post specifically but the general posts about burning in SE vs balanced.
May I ask, when 1Z owners are burning in 4.4mm balanced and 3.5mm SE separately, exactly what are they burning in? It it just the cables or are they referring to the circuity within the 1Z? If it's the cables, I understand in which case it's just a general cable burn-in topic.
However if it's the circuitry within the 1Z, exactly what portion of the circuitry are they thinking they're burning in? I would expect the S-Master HX digital amp portion for the balanced and SE the same - just wires that split to the the different 4.4mm balanced socket and 3.5mm SE socket.Therefore if one has already spent that 200+ hrs burning in that in balanced portion, the only part that is not burnt in would be short wiring to the SE socket. Would that little short segment benefit greatly from burning in?
No it is not just different wiring between balanced and single ended. The separate burn in is specifically for the separate FT Capacitors and Inductor's used for single ended and balanced output formation, in both 1Z and 1A. The S-master chip is less affected by burn in than the capacitors (although it would still benefit from some burn in).
In below picture:
RED is the Single ended circuitry
GREEN is the Balanced circuitry
PINK is the S-Master circuitry (shared by single ended and balanced)
YELLOW is the Power supply circuitry (shared by single ended and balanced)
And the rest of pcb is populated by digital circuitry, cpu, storage, wifi etc.
