SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
Queen6
- Jun 22, 2015
They do still charge, however you can download and install a trial version of Windows 10 that you can install without a license key. For 30 days you get access to all features. After 30 days a few features are disabled and you get a nag message to buy a key but it is still usable.Does Microsoft still charge for its OS? I’ll do the boot camp thing if not.
An alternative to VMware Fusion and Parallels is VirtualBox which is free.
gsiu33
- Feb 5, 2017
I am using WM1Z running fw 3.02 + region J. For me to enjoy WM1A/Z+ in 1Z mode, i just need to install the WM1A/Z+. No need to switch and re-install again, am I correct?Install WM1A/Z++, switch the model to 1Z, then install it again.
MrWalkman
Exactly, the model is already 1Z for a 1Z.
Even Macworld says yes: https://www.macworld.co.uk/feature/mac-software/mac-viruses-list-3668354/
Due too my work I was mac user since OS 9 to Snow Leopard. After then owner of company, where I've worked, changed all the macs to PCs, and QuarkXpress to Adobe InDesign. He said: he has enough to buy whole computer if he wanted only to change processor for faster one (i.e. new G5). Never touched a Mac later
gerelmx1986
Are the rumors by @Facta Fake News? So no new WM1 MK 2?I just did. You’re Fake News
gerelmx1986
I see that these sony DAPs are being quickly outperformed by newer DAPs
Almost all newer players feature minimum. DSD512and pcm 768kHz and between 700 and 1000mW of power with over-ear modes.
I've been dreaming of a mini DMP-Z1 lol with three gains L M and H as well different current levels for different ohm range e.g 0-16 ohm, 16-100 ohm 100-300 ohm 300-600 ohm and >600 ohm HP impedance haha
nc8000
They may be outspeced but are they being bettered on sound and usabillity ?
gerelmx1986
I was thinking the same thing, they look wow on number and specs wise PoV buy they do really sound *that good*? What I would love to see is separated battery a la DTR-1 DMP-Z1 Ibasso maxThey may be outspeced but are they being bettered on sound and usabillity ?
aceedburn
They may be packing older tech and specs but they sound way better than all of the newest high end daps. I’ve tried most of them. Sound is the most important factor to me. WM1A/Z beats everything out there hands down. Especially with the custom firmwares.I see that these sony DAPs are being quickly outperformed by newer DAPs
Gamerlingual
What do you guys think would be a good pair of IEMs to get that don’t fall out easy that feature the 4.4mm Pentaconn connector? Seems like the only options I see are from Sony, Sennheiser, FiiO and Audio Technica. Purpose to listen on the train and anytime on the go when using the 1A or 1Z
gerelmx1986
I have my M7 currently with xelastecs, they do isolate. But havent tested on a train setting. Tried the M7 on the German bullet train and they do isolate very well using the sony hybridsWhat do you guys think would be a good pair of IEMs to get that don’t fall out easy that feature the 4.4mm Pentaconn connector? Seems like the only options I see are from Sony, Sennheiser, FiiO and Audio Technica. Purpose to listen on the train and anytime on the go when using the 1A or 1Z
Orion beta version for WM1A >> Here
Just update stock 3.02 firmware first and then install Orion sound tune firmware. Restart your walkman and that's it.
You can use back to stock tool also if prefer over the official update firmware. If any problem installing it let me know.
Hello WM1A/Z Fans out there,
i will receive my WM1A tomorrow and i will install a custom firmware for WM1Z sound
Which firmware is recommend? Can i just install the WM1A/Z+ Firmware from MrWalkman and switch to 1Z Sound?
Do i understand correctly that the Chameleon Firmware is just the Stock Firmware with option to switch between the Models? But WM1A/Z+ Firmware is the improved Firmware also with the option to switch?
Thanks for you help
Thanks for you help
- Status
Total: 24 (members: 0, guests: 24)
