miguel.yarce
I don't own the 1Z, but I'm fairly certain that a WM1A with CHAMELEON 2.0, switched to 1Z, sounds the closest possible to the actual 1Z, minus the hardware differences.
The soundstage is indeed wide. It's wider than the WM1A, and also wider than the FiiO M11 PRO. The FiiO DAP is the only other player I owned.
My opinion is that these players have their own way of presenting the music. I say this because the WM1Z doesn't have that soundstage just because of the different components. So it's obvious that Sony tuned these players differently.
For example, I like soundstage. I don't want the sound to be as technically accurate as possible, I just want to hear something I like, so WM1Z would be a nice player to own. Luckily, WM1A can come very close to that, and I don't feel like I need to buy the WM1Z. I was considering it at some point, some months ago, but not anymore.
In the end it should be about experimentation and finding out what you like. Reviews can help you get an idea about a certain product, but in the end it's your experimentation with it that will lead you to a conclusion.
By the way, I get that we like these players so much, and we may feel aggressive when someone may seem like trying to say something bad about them. Don't hesitate to ask questions if you have any.
Nice work here MrWalkman!
I had the wm1a a few months ago and changed it for a fiio m11pro, ibasso dx200 amp8 and a hiby r6pro. First off all I was looking for more amplification and something to try the android on DAPs. The big issue was that I didnt find the organic and rich sound from sony, I felt the soundstage on the M11Pro very wide and a lot of air and space between layers, also black floor, I liked that a lot but IMO the sound was a little bit cold. Only the ibasso dx200 amp8 was very near to that kind of sound I was looking for and with more amplification than wm1a, but the battery life and lag issues forced me to sell it very fast.
I had the chance to buy again the wm1a (with less than 200h) and believe me your Chamaleon 2.0 is wonderful!! The soundstage is at the same level or even better than m11pro, the bass is better IMO too. The only thing I miss is that black floor that the THX amp provides.
I am experienced a little less battery life than before with this wm1a, I suppose that it is because of the better amplification that the software is demanding now with the new FW.
Again Nice Work!!
Regards.
MTY
Many thanks!
